RotaxEngines-List Digest: 2 Msgs - 09/18/20
cbcaeromc(at)gmail.com
PostPosted: Sat Sep 19, 2020 6:15 am    Post subject: RotaxEngines-List Digest: 2 Msgs - 09/18/20 Reply with quote
I’m no longer in the market for an engine. Please remove me from your list. Thanks!!
On Sat, Sep 19, 2020 at 2:46 AM RotaxEngines-List Digest Server <rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)> wrote:
Today's complete RotaxEngines-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the RotaxEngines-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2020-09-18&Archive=RotaxEngines
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2020-09-18&Archive=RotaxEngines
                           RotaxEngines-List Digest Archive
                     Total Messages Posted Fri 09/18/20: 2
Today's Message Index:
     1. 07:20 PM - Rotax 912 Eating Ignition Modules  (Guy Buchanan)
     2. 07:27 PM - Re: Rotax 912 Eating Ignition Modules  (william sullivan)
________________________________  Message 1  _____________________________________
Time: 07:20:05 PM PST US
Subject: RotaxEngines-List: Rotax 912 Eating Ignition Modules
From: "Guy Buchanan" <gebuchanan(at)cox.net (gebuchanan(at)cox.net)>
A friend has a 912uls in a Kitfox that seems to be eating ignition modules. He's
gone through three. Yes they were all old. Yes new ones work, but we're worried
that maybe his plane is producing electrical noise detrimental to the modules.
We did some testing using an oscilloscope looking for voltage spikes in the
ground wire during start up and shutoff. For various reasons we weren't able
to capture any voltage spikes during start and stop, but did capture some very
messy noise signatures while running. Picture 1 shows one module's ground wire
while "open". Note +/- 30V peaks and a regular 30hz sawtooth. Picture 2 shows
the same ground "grounded". We did some further testing of the input and output
to the voltage regulator and those voltages appeared relatively clean. Question:
is it possible the ignition module is being damaged by the voltage noise,
regardless of source? Should we apply some caps to the ground wires to kill
the noise?
Guy Buchanan
K-IV 1200 / 912Uls / Warp / 500 hours and flying again.
Now a glider pilot too.
http://forums.matronics.com/viewtopic.php?p=498422#498422
http://forums.matronics.com//files/labnation_screenshot2_112.png
http://forums.matronics.com//files/labnation_screenshot0_140.png
________________________________  Message 2  _____________________________________
Time: 07:27:33 PM PST US
From: william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)>
Subject: Re: Rotax 912 Eating Ignition Modules
 My gut instinct says clean and tighten all grounds. If a component grounds
 through it's base, take off the unit and clean and ground the contact area
. Good luck!
 Bill Sullivan
     On Friday, September 18, 2020, 10:21:35 PM EDT, Guy Buchanan <gebuchan
an(at)cox.net (an(at)cox.net)> wrote:
t>
 He's gone through three. Yes they were all old. Yes new ones work, but we'
re worried that maybe his plane is producing electrical noise detrimental t
o the modules. We did some testing using an oscilloscope looking for voltag
e spikes in the ground wire during start up and shutoff. For various reason
s we weren't able to capture any voltage spikes during start and stop, but
did capture some very messy noise signatures while running. Picture 1 shows
 one module's ground wire while "open". Note +/- 30V peaks and a regular 30
hz sawtooth. Picture 2 shows the same ground "grounded". We did some furthe
r testing of the input and output to the voltage regulator and those voltag
es appeared relatively clean. Question: is it possible the ignition module
is being damaged by the voltage noise, regardless of source? Should we appl
y some caps to the ground wires to kill the noise?
Guy Buchanan
S -
WIKI -
=C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin.
http======================
_-=             - List Contribution Web=                       --> http://www.matronics.com/contribution==============
