Soft start
dpark
PostPosted: Sat Sep 19, 2020 8:33 am    Post subject: Soft start Reply with quote
I have just fitted two new soft start modules to my Rotax 912ULS. Should they both be activated by the start switch and start on both modules. or select only one module to start then activate the second by going to both. I have only wired up one module at the moment but have installed wire to be used from the second module if it is ok to do so.?
Any experts out there?
G-LDVO
Dave Park
Dave Park
Dave Park G-LDVO Europa XS Trike 912uls
Guy Buchanan
PostPosted: Sat Sep 19, 2020 10:33 am    Post subject: Soft start Reply with quote
No expert, but I started on one.
Guy Buchanan
Ramona, CA
Deceased Kitfox IV-1200 / 912-S / Warp 3cs / 600 hrs
Glider pilot, too
G-LDVO
Dave Park
Dave Park
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Griffo
PostPosted: Sat May 08, 2021 9:12 pm    Post subject: Re: Soft start Reply with quote
Again - no expert - From my understanding, the suggestion to start on one module, predates the introduction of "Soft Start" (SS) . It was a potential way of achieving a soft start.
The fitting of the SS system (2 modules & a flywheel) should remove the need for this obsolete technique (if it ever had any effect).
