ADS-B GPS / WAAS antenna install
rparigoris
PostPosted: Thu Sep 24, 2020 10:24 am    Post subject: ADS-B GPS / WAAS antenna install Reply with quote
Hi Group We have a Garmin GA35 GPS / WAAS antenna that needs installing for ADS-B Garmin GDL-82. We want to install it about 2 feet aft of doors under ceiling. Has anyone put a GPS antenna there? Any pics? What size and shape ground plane did you use? Garmin is calling for a ground plane to extend 7.5" from the edge of antenna all around which will make it an approx. 19" circle. Thx. Ron P.
europa10(at)bellsouth.net
PostPosted: Thu Sep 24, 2020 2:18 pm    Post subject: ADS-B GPS / WAAS antenna install Reply with quote
Ron,
Normally a GPS antenna does not need a ground plane. It's part of the
antenna. I'm guessing they are calling it a ground plane when it's just
shielding RF from the transponder or com radio. I installed the EchoUAT in
my plane which uses a GPS with integral antenna. I just mounted it on a
piece of aluminum the width of the GPS and bent in an L shape and bolted to
the top of the back bulkhead. I'm getting a good GPS signal in my plane in
the basement.....
Bill Henderson
N51EU
Europa Monowheel Classic
Loganville, GA
rparigoris
PostPosted: Thu Sep 24, 2020 4:14 pm    Post subject: Re: ADS-B GPS / WAAS antenna install Reply with quote
Hi Bill The Garmin GA 35 is an active antenna and requires a ground plane that extends 7.5" off the edge of the antenna. Somehow 5vdc gets put in and being active it amplifies signal. I spoke to Garmin and Steinair and both said it's necessary. Comant antenna does not need a ground plane. Ron P.
davidjoyce(at)doctors.org
PostPosted: Fri Sep 25, 2020 12:03 am    Post subject: ADS-B GPS / WAAS antenna install Reply with quote
Ron, I have a GA35 antenna for my G3X touch system with GPS20A and GTX45R. The installation instructions at the time (Rev B) made no mention of a ground plate and mine is installed at head level between the doors on a ply panel filling that recess with no form of ground plate. It has worked perfectly with all tests OK. I note that in the current Rev F instructions it does not say a ground plane is necessary, simply something like ‘for best results a ground plane is advisable.’ It would not be too difficult putting a ground plane in that space although it would not be as wide as recommended but I see no reason to do so in the light of my experience. Regards, David Joyce, GXSDJ
On 2020-09-25 01:14, rparigoris wrote:
--> Europa-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>Hi Bill The Garmin GA 35 is an active antenna and requires a ground plane that extends 7.5" off the edge of the antenna. Somehow 5vdc gets put in and being active it amplifies signal. I spoke to Garmin and Steinair and both said it's necessary. Comant antenna does not need a ground plane. Ron P.Read this topic online here:http://forums.matronics.com/viewtopic.php?p=4985; --> http://www.matronics.com/Naviga=======================ref="http://forums.matronics.com" target="_blank" rel="noopener noreff="http://wiki.matronics.com" target="_blank" rel="noopener noreferre========================http://www.matronics=====================
PostPosted: Fri Sep 25, 2020 2:30 am    Post subject: ADS-B GPS / WAAS antenna install Reply with quote
Ron, As a P.S. I should say that my GA35 is in the over head space along with an antenna for my back up GPS496 because I have my nav aerial at the top of the tunnel just behind the D panel and my transponder antenna attached to the bottom of the tail weight tower and of course the radio antenna in the tail fin. That plan hoped to spread them out optimally and it has worked very satisfactorily. David
On 2020-09-25 09:02, davidjoyce(at)doctors.org.uk wrote:
Ron, I have a GA35 antenna for my G3X touch system with GPS20A and GTX45R. The installation instructions at the time (Rev B) made no mention of a ground plate and mine is installed at head level between the doors on a ply panel filling that recess with no form of ground plate. It has worked perfectly with all tests OK. I note that in the current Rev F instructions it does not say a ground plane is necessary, simply something like &lsquo;for best results a ground plane is advisable.&rsquo; It would not be too difficult putting a ground plane in that space although it would not be as wide as recommended but I see no reason to do so in the light of my experience. Regards, David Joyce, GXSDJ
Duncan McFadyean
PostPosted: Fri Sep 25, 2020 7:44 am    Post subject: ADS-B GPS / WAAS antenna install Reply with quote
Ditto everything that David said in regard to the GA35 and mounting between doors.
Mine is an early version c 2002, outputs NMEA (so not just an antenna) and only 9 channels.
However, I have found it to occasionally drop in steep turns; maybe it just doesn't like turning.
Duncan McF.
Duncan McFadyean
PostPosted: Fri Sep 25, 2020 9:04 am    Post subject: ADS-B GPS / WAAS antenna install Reply with quote
Correction: 12 channels.
On 25 September 2020 at 16:41 D McFadyean <ami-mcfadyean(at)talktalk.net> wrote:
Duncan McF.
h&jeuropa
PostPosted: Sat Sep 26, 2020 3:32 am    Post subject: Re: ADS-B GPS / WAAS antenna install Reply with quote
Ron,
Our GPS antenna (GNS 430) is mounted on a aluminum plate which is attached to the top of the fuselage aft of the baggage bulkhead. I think it is about 12" diameter and I just used wood spacers about 2"-3" long bonded to the fiberglas.
The main reason for posting is that we had a lot of difficulity finding a place for our magnetometer that isnt affected by RF from the comm antenna (dipole on vertical fin per the manual). The place that finally worked is overhead between the doors. Even there we had to use ferrite beads on the wires. I wanted to alert you to this potential problem before you mount your GPS antenna there.
Jim
rparigoris
PostPosted: Sat Sep 26, 2020 7:29 am    Post subject: Re: ADS-B GPS / WAAS antenna install Reply with quote
Hi Group To all that replied, thank you. Jim, what wires did you put ferrite beads on? The magnetometer wires? Where, how many and what size did you use? Ron
h&jeuropa
PostPosted: Sun Sep 27, 2020 4:05 am    Post subject: Re: ADS-B GPS / WAAS antenna install Reply with quote
Ron,
This is an early GRT EFIS magnetometer that has two 3 wire shielded cables. I put ferrites on both wires.
GRT recommends placing the magnetometer in the wing tip. But since I anticipated using both sets of wings, I did not want to have to recalibrate the magnetometer when switching wings, hence the interior placement overhead.
Jim
