Oil tank support bracket
rlborger(at)mac.com
PostPosted: Wed Sep 30, 2020 6:03 pm    Post subject: Oil tank support bracket Reply with quote
Steve,
You can find a copy of the oil bracket drawing on the Europa Club website.
https://www.theeuropaclub.org/building/engine-and-fuel-system/rotax-912-and-914-engines
I hope this helps.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop.Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop.3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Sep 30, 2020, at 8:05 PM, Steve Ivell <SteveIvell(at)pestproof.co.uk (SteveIvell(at)pestproof.co.uk)> wrote:
Hi All
I need to make the oil tank bracket as shown in the build manual, which refers to a template but there isn’t one in the online version.
<image001.jpg>
Can anyone help please?
Kind Regards
Steve Ivell
G-STES
XS Tri – 90% built….90% left to do!!!!
Mob: 07971 128842
E-mail: steveivell(at)pestproof.co.uk (steveivell(at)pestproof.co.uk)
rparigoris
PostPosted: Wed Sep 30, 2020 9:09 pm    Post subject: Re: Oil tank support bracket Reply with quote
Hi Steve I sanded a radius on a piece of aluminium to make the radiused bend, clamped to a table and bending was easy. Here's some pics: https://1drv.ms/u/s!Ah1S270Nwg9Vyxc4F-HgDE4FK1mf?e=keZYF8 I used a combo tool to make 90 degree bend and the slip rollers to make the large radius. Ron P.
n7188u
PostPosted: Thu Oct 01, 2020 12:10 pm    Post subject: Re: Oil tank support bracket Reply with quote
I was lucky that at work we had a small press brake like this one:
https://www.eastwood.com/eastwood-press-brake-attachment.html?gclid=CjwKCAjw_NX7BRA1EiwA2dpg0jDX8-W9VjCLjU9zezDWsllOo0D_HFVvArAxtvWUqrX4n9FTTJyG0hoCQLsQAvD_BwE
The one I used was not used with a press. It has a small lever to move the blade down.
Not suggesting you buy one just for this bracket but boy did it make doing those tight bends easy. I also made the curve part with it. Bend a little, move 5mm bend a little again. Yes it ends up a little steppy but looks and works nice.
Best,
Chris
