field current supplied from B lead instead of from main bu
PostPosted: Sun Oct 04, 2020 8:47 am    Post subject: field current supplied from B lead instead of from main bu Reply with quote
At 11:11 PM 10/3/2020, you wrote:
--> AeroElectric-List message posted by: "johnbright" <john_s_bright(at)yahoo.com>
Hi Bob,
Someone in my sphere suggested getting field current from the B lead instead of from the main bus.
This way if the B lead shorts to ground and the fuselink opens, the field will be de-energized.
Marked up snip of Z101B attached.
Comments?
If there is a fault that opens the fusible
link, then the alternator is isolated from
the ship's systems. While the field would
still be energized, the resulting condition
is internal to the alternator and not a
threat to the rest of the airplane.
If the regulator senses bus voltage through
the breaker, then you will depress bus voltage
by whatever drop occurs in the b-lead. Further,
the b-terminal to field breaker lead becomes and extension
of the bus and would need to get a fusible
link at the b-lead.
Presently, I see no particular advantage
for doing this.
johnbright
PostPosted: Sun Oct 04, 2020 10:45 am    Post subject: Re: field current supplied from B lead instead of from mai Reply with quote
link at the b-lead.
for doing this.
Thanks Bob.
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
