Can I turn off Mode C transponder and ADS-B when soaring?
rparigoris
PostPosted: Thu Oct 08, 2020 7:01 am    Post subject: Can I turn off Mode C transponder and ADS-B when soaring? Reply with quote
Hi Group In process of wiring at the moment. Question: When soaring (motor off) at an uncontrolled field in the US do I need to keep Mode C transponder and ADS-B on? Thx. Ron P.
MJKTuck(at)cs.com
PostPosted: Thu Oct 08, 2020 7:47 am    Post subject: Can I turn off Mode C transponder and ADS-B when soaring? Reply with quote
Probably depends on the airspace you are in. Class C on up I think the answer is yes.
Martin
http://forums.matronics.com/viewtopic.php?p=498700#498700
John Wighton
PostPosted: Thu Oct 08, 2020 11:46 pm    Post subject: Re: Can I turn off Mode C transponder and ADS-B when soaring Reply with quote
An answer could be to buy a bigger battery or invest in solar cells, PV. The safety improvement derived from EC devices outweights the operational issues?
John Wighton
Europa XS trigear G-IPOD
