RV8-List Digest: 1 Msgs - 10/18/20
edwclg
PostPosted: Mon Oct 19, 2020 8:00 am    Post subject: RV8-List Digest: 1 Msgs - 10/18/20 Reply with quote
Thanks Stan,The Kroil will actually penetrate the outer cover?
Ed
On Mon, Oct 19, 2020 at 2:47 AM RV8-List Digest Server <rv8-list(at)matronics.com (rv8-list(at)matronics.com)> wrote:
Today's complete RV8-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the RV8-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2020-10-18&Archive=RV8
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2020-10-18&Archive=RV8
                           RV8-List Digest Archive
                     Total Messages Posted Sun 10/18/20: 1
Today's Message Index:
     1. 03:10 PM - Re: RV8-List Digest: 1 Msgs - 10/17/20  (speedy11(at)aol.com (speedy11(at)aol.com))
________________________________  Message 1  _____________________________________
Time: 03:10:54 PM PST US
Subject: Re: RV8-List Digest: 1 Msgs - 10/17/20
Ed,Those cable require regular maintenance.=C2- If you don't they will te
nd to bind.=C2- That is true of all cables, not just Van's.Personally I s
pray them with Kroil at each annual, and sometime more often.=C2- Sprayin
g the outside of the cable housing is sufficient and allow it to creep insi
de.=C2- It is easy to see when it has absorbed inside.=C2- There are ce
rtain sections of my cables that I can't spray to to limited access, but th
ey are mostly straight sections and thus, less likely to bind.Regards,Stan
Sutterfield
Time: 09:42:17 AM PST US
From: edward Clegg <edwclg(at)gmail.com (edwclg(at)gmail.com)>
Subject: Re: RV8-List Digest: 0 Msgs - 10/16/20
Has anyone had problems with the Vans supplied throttle/mixture cables for
RV 8s'?
Both bound up after 8 years, I replaced them and now have an issue with
mixture cables' throw reduced to under 2 inches resulting in inability to
shut a/c down with mixture.
Ed Clegg
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV8-List
