heavy left wing, how trim tabs work.
esp3500
PostPosted: Sat Nov 07, 2020 6:01 pm    Post subject: heavy left wing, how trim tabs work. Reply with quote
Hay Guys
I have gotten some hours on my very old freshly restore twinstar.
I have everything worked out except the left wing is heavy.
My flightstar has the same problem so maybe you can help me kill two birds .
I have put a trim tab on the left wing.
i bent the tab up and the problem got better so I bent it up some more but got no additional improvement .
How exactly does the trim tab work and should I have put it on the right wing?
any help would be greatly appriciated.
Watkinsdw
PostPosted: Sun Nov 08, 2020 5:15 am    Post subject: Re: heavy left wing, how trim tabs work. Reply with quote
When I had my Mk III Classic, I had big washers in the rear attachment point of the left wing. There were two on one side of the wing spar, and one on the other side, within the u-shape receiver. By rearranging the double stack to one side or the other, I could adjust the roll trim for flying solo, or with a passenger. Don’t know if this will work for you, but it did for me..
neilsenrm(at)gmail.com
PostPosted: Sun Nov 08, 2020 5:53 am    Post subject: heavy left wing, how trim tabs work. Reply with quote
The problem is your Kolbs have a trim issue. The factory makes an optional adjustable universal joint (this is the wing rear attach fitting) that I think Dave is talking about and this is the best fix for this problem.
Rick Neilsen
Redrive VW Powered MKIIIC
On Sun, Nov 8, 2020 at 8:18 AM Watkinsdw <david.watkins0(at)gmail.com (david.watkins0(at)gmail.com)> wrote:
--> Kolb-List message posted by: "Watkinsdw" <david.watkins0(at)gmail.com (david.watkins0(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=499305#499305
WIKI -
Richard Pike
PostPosted: Sun Nov 08, 2020 6:04 am    Post subject: Re: heavy left wing, how trim tabs work. Reply with quote
What Rick said.
Something to think about, if you try to raise a wing by lowering it's aileron, you will increase the drag of that wing. Which now adds another factor to the mix by having that side of the airplane want to create yaw.
IMO, if the left wing feels heavy, you are better off adding a downward deflected trim tab to the right wing aileron, raising the right wing aileron to push the right wing down a bit, and then adjust your aileron differential so that when the right aileron is up a hair, the left aileron is in line with the bottom of the left wing so as not to add extra drag to that side.
Anyway, it worked for me, and I made mine adjustable because things change a bit depending on if you are carrying a passenger.
http://oh2fly.net/oldpoops/pg6.htm
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
zeprep251(at)aol.com
PostPosted: Mon Nov 09, 2020 4:58 am    Post subject: heavy left wing, how trim tabs work. Reply with quote
Nice to see some activity on the list. are you flying anything now Rick?
On Nov 8, 2020, at 8:53 AM, Rick Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)> wrote:
Rick Neilsen
--> Kolb-List message posted by: "Watkinsdw" <david.watkins0(at)gmail.com (david.watkins0(at)gmail.com)> When I had my Mk III Classic, I had big washers in the rear attachment point of the left wing. There were two on one side of the wing spar, and one on the other side, within the u-shape receiver. By rearranging the double stack to one side or the other, I could adjust the roll trim for flying solo, or with a passenger. Don’t know if this will work for you, but it did for me.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499305#499305 =========== -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== WIKI - errer" target="_blank">http://wiki.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ===========
esp3500
PostPosted: Mon Nov 09, 2020 1:25 pm    Post subject: Re: heavy left wing, how trim tabs work. Reply with quote
Of course my plane is one of the early model ones but I am curious.
did the plans come with rigging instructions for these planes?
