Airspeed Indicator
Luisito22
PostPosted: Tue Dec 29, 2020 3:04 pm    Post subject: Airspeed Indicator Reply with quote
Does anyone knows where I could find a direct replacement airspeed indicator for my allegro? Or where in the US I could send mine to get calibrated.
Allegro
N43536
hgmckay
PostPosted: Wed Dec 30, 2020 7:06 am    Post subject: Airspeed Indicator Reply with quote
Luis,
How do you know your Airspeed indicator instrument readings are incorrect? Do you have the factory audible stall warning system in your Allegro?
Hugh G. McKay III, P.E. Fellow, Life Member ASCE
Senior Consultant
Worldwide Engineering Inc.
hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
Phone 704-661-8271
Sent from Mail for Windows 10
Sent: Tuesday, December 29, 2020 6:04 PM
To: allegro-list(at)matronics.com (allegro-list(at)matronics.com)
Subject: Airspeed Indicator
Luisito22
PostPosted: Wed Dec 30, 2020 8:41 am    Post subject: Airspeed Indicator Reply with quote
Hello hugh
Hope all is well with you, the stall system is disconnected I was flying over the summer and the horn started going off as I was in Cruise and I could get it to go off.I'm getting a 30 mph difference between my airspeed indicator and my GPS, I tried with my iFly and my Garmin and it's off
On Wed, Dec 30, 2020, 10:07 AM Hugh McKay III <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
Luis,
Senior Consultant
Phone 704-661-8271
Subject: Allegro-List: Airspeed Indicator
Allegro
N43536
hgmckay
PostPosted: Wed Dec 30, 2020 10:14 am    Post subject: Airspeed Indicator Reply with quote
Was your stall system working fine and then suddenly the alarm started while at cruise? Had you noticed the 30 mph airspeed discrepancy between the ASI and your GPS before or after the alarm system started going off? How did you disconnect the stall warning system? You may have an obstruction at or in the stall system port on the leading edge of the right wing. I don’t remember how the port on the leading edge of the wing is connected to the system as a whole.
Senior Consultant
Phone 704-661-8271
Sent: Wednesday, December 30, 2020 11:41 AM
Subject: Re: Airspeed Indicator
Hello hugh
Luis,
Senior Consultant
Phone 704-661-8271
