Zeftronics Regulator Connection Question
farmrjohn
PostPosted: Tue Jan 19, 2021 8:37 am    Post subject: Zeftronics Regulator Connection Question Reply with quote
I have a Zeftronics R15100 voltage regulator that has the following terminals: I-A-S-F. Only three terminals have wires connected to them, I-A-F. For low or high voltage indication it looks like an Electronics International VA-1 voltmeter is used. Everything seems to be working (system shows 14.1 volts when engine running, alternator on), should I move the I lead to the S terminal?
farmrjohn
PostPosted: Fri Jan 22, 2021 3:51 pm    Post subject: Re: Zeftronics Regulator Connection Question Reply with quote
Based on the lack of replies I'll go with "if it ain't broke, don't fix it" as it seems to be working OK. John
