MJKTuck(at)cs.com Guest
Posted: Tue Feb 02, 2021 6:03 pm Post subject: Mono Landing Gear Bungee |
Can anyone recall the diameter of the bungee used to assist gear
retraction on the mono? 3/8 inch maybe?
As I recall there is not much room for it to squeeze through as you go
around the frame. I think 1/2 inch would be too big - I'm pretty sure it
was bigger than 1/4 inch.
Also, what would be a good length to buy?
Martin Tuck
Wichita, KS
ward.t(at)xtra.co.nz Guest
Posted: Tue Feb 02, 2021 7:31 pm Post subject: Mono Landing Gear Bungee |
Hi Martin,
Just measured the old bungee I replaced.
Thickness 7mm = 5/16 just short 3/8. So 3/8”
Length 7m = 30ft
Hope that helps and I am correct.
Tim
Tim Ward
12 Waiwetu Street
Fendalton
CHRISTCHURCH 8052
Hom 03315166
| Quote: | On 3/02/2021, at 15:11, Martin Tuck <MJKTuck(at)cs.com> wrote:
Can anyone recall the diameter of the bungee used to assist gear retraction on the mono? 3/8 inch maybe?
As I recall there is not much room for it to squeeze through as you go around the frame. I think 1/2 inch would be too big - I'm pretty sure it was bigger than 1/4 inch.
Martin Tuck
Wichita, KS
h&jeuropa
Posted: Wed Feb 03, 2021 9:54 am Post subject: Re: Mono Landing Gear Bungee |
Martin,
The parts list that came with our kit shows 10mm x 6 meters for the bungee. We replaced ours a couple years ago with 20 ft of 10mm cord. We got it from Aircraft Spruce.
Jim & Heather
Posted: Wed Feb 03, 2021 10:44 am Post subject: Mono Landing Gear Bungee |
Martin,Jim is correct. They increased the diameter of the bungee in later Europa aircraft to 10mm. I remember now after 20 years.
Tim
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
| Quote: | On 4/02/2021, at 7:02 AM, h&jeuropa <butcher43(at)att.net> wrote:
--> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net>
Martin,
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=500550#500550
====================================================; - MATRONICS WEB FORUM====================================================; - NEW MATRONICS LIST WIKI -
_====================================================bsp; - List Contribution Web Site -
_ &n=======================================================
rparigoris
Posted: Wed Feb 03, 2021 11:26 am Post subject: Re: Mono Landing Gear Bungee |
Hi Martin
I installed bungee with one more loop compared to what manual shows. As per Nev, I left a tail on the bungee so if I want to tighten in future job will be easier.:
https://1drv.ms/u/s!Ah1S270Nwg9VylK4_khn10T8oiq_
Ron P.
