		Tim(at)MyRV10.com Guest
				 Posted: Tue Jun 06, 2006 9:49 pm    Post subject: Pinpoint AHRS Update |
				For those who are closely watching the Chelton/Crossbow AHRS recall, and
 waiting for info on the Pinpoint GADAHRS that will be substituted for
 the Crossbow, I wanted to post a small update.
 I got my unit last week, and got it all installed before my trip to
 Yellowstone.  From an installation perspective, it is not too much
 work to install, especially if you prepare.   With the Chelton supplied
 wiring harness, they plan to locate your AHRS unit behind the panel,
 as it has a remote magnetometer that can mount elsewhere, such as
 in the wing.  The other component that needs to be mounted is the
 OAT probe, necessary because the pinpoint also contains a complete
 air data computer.  If you are already using another EIS for your
 air data, like I'm using my Grand Rapids EIS6000 (chelton version),
 there is special wiring you can do to accomodate both sets of air data,
 so contact D2AV or me for information if you're in this position.
 Nothing too complex.  The other difference is that it requires you
 to plumb a pitot and static line to the AHRS unit, as this is needed
 for Air Data, of course.  The AHRS box also has a GPS antenna connector,
 so consideration should be given to mounting it near the antenna.
 For me, the install went very easily, with the only real big change
 being the fact that the new wiring diagram lists using 3-conductor
 shielded and not using any shields for signal grounds.  So if you're
 awaiting a pinpoint unit, just make sure you have at least one
 3-conductor cable pulled between the AHRS and the screens.  It is
 also used between the AHRS and the MSU.   The rest can be 2-conductor
 shielded.  I won't go into any more detail on the install right now
 though, but this is just a head's up to give people who are waiting
 a couple of tips.  You will also want to plan ahead for how you
 are going to get your pitot and static lines there.
 In my install, I have the AHRS on the same forward tail shelf
 as the last one.  I put the OAT probe next to the access plate
 under the right wing, and for the magnetometer I couldn't decide
 between the wingtip or the tail, but ended up thinking it would
 be easiest for me to mount in the aft section of the tail, on a
 2nd shelf, above the elevator pushrod.  I figured this would give a
 great location from a ferrous metal, and electrical perspective.
 I know the big question is, how does it work.  Well, I can say that
 there are currently a few people, using various types of aircraft, who
 have installed the unit and are test flying it right now.  We are on
 the "demolition team" to test it in a few various small aircraft types,
 and determine if there is anything we can do to cause it to not work
 properly.  It's being done in owner-built planes, to ensure that
 even substandard mounting and wiring won't throw the thing way out
 of whack....hopefully mine isn't too substandard.     Being an AHRS
 that was generated from the Boeing/Airbus type aircraft systems, it
 needs to be tested in smaller aircraft to ensure all is well.  If
 all goes well, it can be released for production deliveries, and if
 anything needs to be checked, it can be retested as needed by the
 team to ensure all will be well when it's delivered.
 I only fill you in on this so that you all know that even though
 you may not have heard anything lately, there is stuff going on
 right now, and progress is being made towards getting them out
 the door.
 As for how it's working for me, I have put about 11-12 hours on it
 in the past few days, and have found nothing at all that I can question
 about it.  I was not overly disappointed in the crossbow, as the only
 things that ever happened to me is that I couldn't get it to boot
 about 10 or 12 times, and in-flight it performed fine.  But I can say
 that this one is performing every bit as good as the Crossbow.  I've
 tried many various attitude maneuvers, some pretty extreme, and
 I've not seen anything negative yet.  I'm almost disappointed, as
 being part of a team to "break" something, I was hoping I'd be more
 useful in helping them test and perfect it.  At any rate, I know
 I was always wondering what the heck was going on, and why we heard
 about it so long ago, but saw nothing in our hands.  I figured I
 should write and let you know that I can now say there is
 progress.  I am told that after I/we have tested it completely that
 they'll be retiring these original units and re-shipping us all
 completed production units with any required updates installed,
 post-retesting, of course.
 You can ask me any questions offline if you wish, but I can't go
 into much detail during the testing period.  I'm sure they want
 to make sure that everything that is said is accurate, including
 any install info.  But, I can maybe at least help keep you pointed
 in the right direction for when you get the pinpoint.
		JeffreyKidd Guest
				 Posted: Thu Apr 11, 2019 4:10 am    Post subject: Re: Pinpoint AHRS Update |
				Electronics are  bought for the good and all ital. paths for the humans. the needs of the appliances and speedy essay review are marked for the individuals. It is assured for the right use of the foes for the humans.
		DannyBo Guest
				 Posted: Sun Jan 24, 2021 3:20 am    Post subject: Re: Pinpoint AHRS Update |
				I see you have a good discussion here about the quality of essay writing and paperwork. I would also like to speak out about the fact that I am a student and very often I do not have enough time to write an essay, because I want to take a walk, so i buy dissertations online. Therefore, I seek help from a service that has been helping me for more than one academic year and has never failed.
