user9253
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Fri Feb 12, 2021 8:43 am Post subject: Van's Aircraft Statement |
Here is a quote from Van's Aircraft FLIGHT TRAINING SUPPLEMENT:
https://www.vansaircraft.com/wp-content/uploads/2020/10/RV-12iS-FTS-4.pdf page 6-6
Quote: | The Rotax 912 iS is equipped with two voltage regulators, one for each generator on the engine. These regulators reject any unused electrical power as heat. Allowing the power usage to fall below 7 amps for extended periods of time may damage the regulators, especially on hot days. |
That can not be true can it? Suppose that 21 amps are available but not
used by the aircraft electrical system. 21 amps x 14 volts = 300 watts
of heat that must be dissipated by the voltage regulators.
Don't modern permanent magnet voltage regulators work by shutting off the
output during part of the AC cycle using SCRs that are in series with the output?
_________________ Joe Gores |
yellowduckduo(at)gmail.co Guest
Posted: Fri Feb 12, 2021 9:18 am Post subject: Van's Aircraft Statement |
Pretty sure I've read all of the current rotax manuals and bulletins
for that engine and there is no such information or caution anywhere.
(and it doesn't make sense anyway for something this large as Joe has
indicated). The temperature limit on the regulators is 80*C and rotax
insists that it be installed in the engine compartment. While there is
an optional additional heat sink available for regulator B it's still an
order of magnitude too small to handle that kind of heat.
Ken
Joe Gores
http://forums.matronics.com/viewtopic.php?p=500656#500656
Ceengland
Posted: Fri Feb 12, 2021 10:57 am Post subject: Van's Aircraft Statement |
Joe Gores
Easy enough to test empirically, if you have the system.
IIRC, early rectifier-regulators really were 'shunt' style regulators,
that would align with the warning from Van's. Newer regulator designs do
seem to use 'switcher' style voltage control, which should function like
typical semiconductors and get hotter as more current flows to the load.
No idea what's used in the iS, but you'd hope it would be the more
modern type.
Charlie
_________________ Charlie |
