Start 914 on A, B or both?
rparigoris
PostPosted: Sat Mar 20, 2021 10:53 am    Post subject: Start 914 on A, B or both? Reply with quote
Hi Group
When starting a 914, is it worth it to start only on Ignition B where advance is 22 BTDC? This would be a little less advance compared to Ignition A where advance is 26 BTDC. Perhaps less chance of kickbacks?
I don't have soft start.
I have heavy duty starter, Earth-X 680C and Airmaster.
I don't have the very old 914 ignition modules with different RPM and timing at lower RPMs, mine has pretty good wire strain relief from factory.
Or start on both A+B Ignitions?
Perhaps get engine cranking with ignition off till max starter RPM?
I have B&C SD20S on vacuum pad, is it worth it to start with field off?
I have a B&C AVC1 regulator for internal generator, is it worth it to start with no power going to AVC1 which will keep internal generator dead?
Thx.
Ron P.
Griffo
PostPosted: Mon Mar 22, 2021 10:32 pm    Post subject: Re: Start 914 on A, B or both? Reply with quote
Seeing as the more knowledgeable are not responding I will give parts of your Q a go:
Sounds like a no brainer but do not attempt to start with a weak battery. You will do damage to your starting system and have a poor start performance (especially cold engine and in cold weather)
For a cold start –
If using ULP/MoGas, it must be fresh, for best starting performance – adding a good “slug” (minimum 20 L) of fresh fuel to a slightly stale tank contents is usually sufficient to bring it up to specifications.
Make sure you run your fuel boost pump until a stable pressure is achieved (turn off).
All non-starting circuits must be off before cranking.
I like to have my choke on full (closed) with just a mm or two of throttle. This will give a very slightly higher than your minimum idle RPM.
After start - Do not be in a hurry to close your choke and then do it gradually, bringing in a bit more throttle to maintain fast idle – at choke full off, engine should be at or about 2-2200 RPM.
Hot start –
Same as above, without any choke. In fact, I like to stop/kill my engine with the RPM slightly above minimum idle, in preparation for the next start.
No start! REST THE SYSTEM to allow cooling – consider possible over rich/flooding may have occurred. If so, OPEN CHOKE & advance THROTTLE (1/3 – 1/2) – ARM BOTH IGNITIONS – when system cooled – (be sure to have brakes fully engaged) CRANK and be ready to reduce RPM (slowly)
No starter motor should be used as a prolonged cranking device – so don’t crank & then engage your ignition. Always arm your ignition (1 and/or 2) and then crank.
As for starting on ignition 1, 2 or both – I prefer both, but many pilots will start on one and then bring in the second.
Soft Start (SS)– First make doubly sure it is not fitted.
If not fitted – consider purchasing/fitting the SS fly wheel. This a fairly easy and low-cost upgrade that will give you some SS capability, without fitting the very expensive SS modules.
If you have the dollars – one SS Module and the fly wheel will give you all the SS you need.
I understand that there was a period where the SS was fitted but not necessarily connected – check for this, as I understand a small piece of wiring harness is all that is needed to bring it into effect.
Can’t answer your Q on the alternator on/off but my gut feeling is that it should make no difference to a starting system in good condition, powered by a good battery.
Your battery, start cables & connector condition is always the lowest cost key to a reliable start.
