Prop thrust
byoungplumbing(at)gmail.c
PostPosted: Mon Apr 05, 2021 8:30 am    Post subject: Prop thrust Reply with quote
Rick said and it got me thinking....The CG is forward of the position of the prop butalso fairly close to the CG. Press down on the prop and the plane pitchesup, lift and it pitches down. .
Still trying to get this figured out in my mind.   So ive gone to the extreme.  I've seen a photo of a low wing plane with the engine mounted on top of the rudder...  The prop is mounted 7 feet behind and above  the cg and center of drag  (cdrag) much like the kolb but much further back, in my mind the physics remains the same but on a larger scale than the kolb.   Because the thrust is higher than the cg /c drag there will still be some nose down tendancy with increased  power.   The following examples may (i hope) shed some light on how to neturalize it.
Now this is where i am taking a good size leap, and if i am wrong I'll apologize in advance.
Now in the following examples if the angle changes don't register in your mind the pressure changes to the aircraft...  Draw 2 pictures.  One of the aircraft ive described, and one of an engine and prop.  Place the second pic on top of the first, and if needed over exaggerate the thrust angle even more,,,  say 15 and 30 deg.  If you ask why i suggested this, ive done it.
Let's assume that the aircraft is flying straight and level, and the engine thrust line is parallel to the direction of travel.  The thrust is above the cg/cdrag  so there will be an amount of  nose down tendancy  that can be compensated for with a small amount of up elevator.  When the power is cut, the nose down tendancy (forces) go away and the nose of the plane goes up.
I will exaggerate to make a point....
If we raise the front of the engine 2 deg.   The thrust  above the cg/cdrag will have a  tendancy to push the nose down  adding the up pressure from the prop thrust angle on the tail will require even more  up elevator.   When the power from cruise is cut the higher than cg/cdrag is removed also the  2 deg. uplift on the tail is removed.   This should cause a much greater nose up situation.
If we lower the front of the engine 2 deg the majority of thrust is still above the cg/cdrag and the nose down tendancy is countered by down pressure on the tail from the prop pushing down 2 deg.    No elevator is needed and when we cut power there should be no tendancy for the nose to drop or raise.
Try again with 4 deg of down angle ln the engine.(lower the front of the engine)..   The thrust line is still above the cg/cdrag so a small nose down moment is still present,  but now there is much  more down  force from the prop thrust angle.  This additional down force  to the rear of cg(tail) should require down elevator to compensate.    If we remove power.  The nose drops.
Now I have used a high tail mounted engine in the example.  But would imagine that the same principals apply to the kolbs.  The moment arms are much smaller on a kolb,  and because of the shorter moment arms, some of the angles would be greater.
Burt Rutan is reported to have said that on a bird, every feather makes a difference in how it flies..      not accounted for in my explanation is relationship between cg and c lift, Moving cg with fuel burn,  changes in attitude at different flight speeds, climbing or descending,  the exact relationship (arm)between cg/cdrag and the thrust line of the engine prop.   I did however assume the thrust line stayed above the cg/cdrag.
Please remember that the large angle changes in the narration were used to induce  thought, not to be used in real life trials.
Again if i have it wrong,  please , someone HELP me understand.
Boyd Young  mkiii Utah
Sorry this got overly long
Jerry-TS-MkII
PostPosted: Mon Apr 05, 2021 9:27 am    Post subject: Prop thrust Reply with quote
Just to add a few comments about this whole discussion... (and yeah, all
of this could be wrong too)
You might need a super computer to do the full blown flight simulation..
but the big factors (I believe) are the following:
You have the engine thrust vector.. how much it is pitched up or down.
Considering it's location, I doubt that is the primary contributor, if
changes are slight.
You have the drag of the wing, as profile AND the dynamic drag (due to
producing lift, which changes with speed and angle of attack).. AND there
is a pitching moment caused by how different airfoils react at different
angles of attack.
You have the total aircraft profile drag, which is WELL BELOW the wing,
engine, and thrust vectors.. ie, all of the drag from the fuse, pilot,
landing gear. And all of that changes with the square of the airspeed.
But I would suspect it doesn't change much with the attitude of the
aircraft, (if right side up).
You have the center of mass, which may be only slightly higher than the
center of drag.. considering again, undercarriage, pilot weight, fuel (in
most, behind the pilot but low), and the mass of the fuse
And you have the mass distribution over the whole of the air-frame. If
all the heavy stuff is close in to the center of mass, it's different than
if it is further out. (See ice skaters spinning.. arms in = faster, etc).
We'll HOPE that's not changing while we fly.. but it does have an effect on
how easily the plane pitches, with power changes applied.
Aircraft designs can use a lifting stab.. such that with increased
airspeed, (producing more lift).. the flying stab tends towards keeping it
level, but still climbing. (HP above what is required for level flight,
produces ROC). A positive angle of attack on the flat stab of the Kolb has
a similar, but reduced effect. And the size of the tail area * tail arm =
the amount of control authority. Kolb tail feathers are really small in my
opinion, esp compared to those of my Drifter for example.
But the one thing which comes to my mind, is that by having the engine
mounted above and behind both the cg and center of drag and mass, is that
if near stalling, the quick application of power, will A) pull more air
across the wing, reducing the stall point, and forcing the nose down,
reducing the angle of attack. Both good things. But none of the Kolbs are
designed by aero-space engineers (or that I am aware of).. so it may well
have some characteristics which require trim, or human reaction to huge
power change inputs. Flying with my dad (old hat pilot).. and knowing a
little bit about engines in general.. huge/fast power changes are not
ideal, if they can be avoided.. either to accelerate or decelerate! And
with our non-certified engines, if they are running, may be more important
than anything else.
Making changes to a EXP? No problem there, if done carefully and with
some research. And yeah, engine placement is rather easy to edit. If you
are going to re-engineer it, there are a lot of factors, and just as many
things which could benefit from being revised. But it's not a simple
puzzle.
On Mon, 5 Apr 2021 10:30:07 -0600, B Young <byoungplumbing(at)gmail.com>
the prop but
pitches
extreme.  Ive seen a photo of a low wing plane with the engine mounted
Now this is where i am taking a good size leap, and if i am wrong Ill
Now in the following examples if the angle changes dont register in your
this, ive done it.
Lets assume that the aircraft is flying straight and level, and the
I will exaggerate to make a point....If we raise the front of the engine
situation.
still
to drop or raise.
a
cg/cdrag.
Boyd Young  mkiii UtahSorry this got overly longDo not archive
neilsenrm(at)gmail.com
PostPosted: Mon Apr 05, 2021 10:28 am    Post subject: Prop thrust Reply with quote
1957
Very informative but even reading between the lines I missed the conclusion.
Rick Neilsen
Redrive VW Powered MKIIIC
On Mon, Apr 5, 2021 at 1:30 PM <1957grnchev(at)bluemarble.net (1957grnchev(at)bluemarble.net)> wrote:
--> Kolb-List message posted by: <1957grnchev(at)bluemarble.net (1957grnchev(at)bluemarble.net)>
changes are slight.
angles of attack.
than anything else.
puzzle.
On Mon, 5 Apr 2021 10:30:07 -0600, B Young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)>
> the prop but
pitches
> this, ive done it.
> situation.
still
> to drop or raise.
a
> cg/cdrag.
WIKI -
Jerry-TS-MkII
PostPosted: Mon Apr 05, 2021 11:47 am    Post subject: Prop thrust Reply with quote
Like the first line, it says, "to add a few comments".. So two conclusions
could be drawn. Each plane is different, from configuration, loading, W&B,
HP and prop, etc. And "Your results may vary".
On Mon, 5 Apr 2021 14:28:26 -0400, Rick Neilsen <neilsenrm(at)gmail.com>
conclusion.
Rick NeilsenRedrive VW Powered MKIIIC
all
simulation..
Considering its location, I doubt that is the primary contributor, if
changes are slight.
there
different
angles of attack.
But I would suspect it doesnt change much with the attitude of the
(in
all the heavy stuff is close in to the center of mass, its different
than
etc).
Well HOPE thats not changing while we fly.. but it does have an effect
on
it
flight,
has
arm =
in my
that
are
well
a
important
than anything else.
you
many
things which could benefit from being revised.  But its not a simple
puzzle.
of
> the prop but
pitches
the
mounted
above
further
than
will
it.
your
of
thrust
> this, ive done it.
thrust
engine
push
the
cruise
> situation.
still
elevator
nose
> to drop or raise.
the
nose
force
of
makes
a
explanation
descending,
the
> cg/cdrag.
used
-List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?Kolb-List
WIKI -
Links:
[1] mailto:1957grnchev(at)bluemarble.net
[2] mailto:1957grnchev(at)bluemarble.net
[3] mailto:byoungplumbing(at)gmail.com
