Rotax 582 high EGT's
NebraskaYak
PostPosted: Sun Apr 11, 2021 6:32 pm    Post subject: Rotax 582 high EGT's Reply with quote
Hi All,
Just got my 582 powered plane out after winter hibernation. Everything was fine when we parked it and now both EGT's are trending high, right up to 1200 on takeoff and over 900 at 3000rpm. Never saw them so high before. Rebuilt fuel pump, checked carb floats, new fuel lines and filter, fresh gas and swapped egg gauge with no changes. Any ideas what would cause both to be so high all of a sudden?
Thanks for the help!
Andrew
williamtsullivan(at)att.n
PostPosted: Sun Apr 11, 2021 6:47 pm    Post subject: Rotax 582 high EGT's Reply with quote
Is it fresh gas?
Bill Sullivan
On Sunday, April 11, 2021, 10:34:47 PM EDT, NebraskaYak <andrew.malousek(at)comcast.net> wrote:
--> RotaxEngines-List message posted by: "NebraskaYak" <andrew.malousek(at)comcast.net (andrew.malousek(at)comcast.net)>
Hi All,
Andrew
http://forums.matronics.com/viewtopic.php?p=501356#501356
_/Navigator?RotaxEngines-List" target="_blank">http://www.matronics.com/Na= - MATRONICS WEB FORUMS= --> /wiki.matronics.com" target="_blank">http://wiki.matronics.com
http://www.mat====
NebraskaYak
PostPosted: Sun Apr 11, 2021 6:55 pm    Post subject: Re: Rotax 582 high EGT's Reply with quote
yep, drained and filled with fresh premix
PostPosted: Mon Apr 12, 2021 6:13 am    Post subject: Rotax 582 high EGT's Reply with quote
My only other thought is to check your connections. Oxidation would cause a change in electrical resistance. Pull the plugs, and clean the contact surfaces.
Bill Sullivan
On Sunday, April 11, 2021, 10:56:22 PM EDT, NebraskaYak <andrew.malousek(at)comcast.net> wrote:
http://forums.matronics.com/viewtopic.php?p=501358#501358
http://www.matronics.com/Navigator?RotaxEngines-; - MATRONICS WEB FORUMS -
http://forums.matronbsp; - NEW MATRONICS LIST WIKI -
_-========================sp; - List Contribution Web Site -
http://www.matronics.com/contributi======================
skyguynca
PostPosted: Mon Apr 12, 2021 7:03 am    Post subject: Rotax 582 high EGT's Reply with quote
Seals are leaking, crankshaft seals probably. It will suck in air past the
seals and cause you to run lean.
They dry out and start leaking after years of being installed. Doesn't
matter how many hours. Long sits during winters without being preserved
properly can be the culprit too.
David
ppsel03
PostPosted: Tue Apr 13, 2021 4:51 am    Post subject: Re: Rotax 582 high EGT's Reply with quote
NebraskaYak wrote:
Hi All,
Andrew
Assuming you've 2 plugs per cylinder, One of the mags is not sparking. Unburned fuel is burning in the exhaust.
EuropaXS 914UL Turbo
Guy Buchanan
PostPosted: Wed Apr 14, 2021 3:17 pm    Post subject: Rotax 582 high EGT's Reply with quote
Check for an air leak at the boots. Unfortunately your crank seals may
have dried and allow air to pass. There's a way to check but I don't
remember it. I think there's a spec for crankcase vacuum or manifold
vacuum that might tell you something about leakage.
On 4/11/2021 7:32 PM, NebraskaYak wrote:
Hi All,
Andrew
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
