Thread Lacing Tape
Goto page 1, 2  Next
mcurley68(at)hotmail.com
PostPosted: Fri May 07, 2021 6:10 am    Post subject: Thread Lacing Tape Reply with quote
I recently read a recommendation for using thread lacing tape instead of ty-wraps to organize wire looms. Also noted that firewall forward should be using "high temp" lacing. What is this high temp lacing and where can I get an appropriate quantity for one aircraft?
Mark Curley
Lake Havasu City, AZ
building Van's RV-6
stein(at)steinair.com
PostPosted: Fri May 07, 2021 7:39 am    Post subject: Thread Lacing Tape Reply with quote
Hi Mark,
I’m afraid we don’t have any high temp lacing cord.  Typically for Firewall Forward we usually use either adel type clamps to secure things, or we use high temp cable ties (tefzel).
Stein
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> On Behalf Of Mark Curley
Sent: Friday, May 7, 2021 9:10 AM
Subject: Re: Thread Lacing Tape
Mark Curley
building Van's RV-6
Voyager
PostPosted: Fri May 07, 2021 9:16 am    Post subject: Thread Lacing Tape Reply with quote
It’s not cheap and I have yet to find a place to buy small quantities.
https://www.digikey.com/catalog/en/partgroup/tech-lace-series-nomex/35160
On May 7, 2021, at 11:42 AM, SteinB <stein(at)steinair.com> wrote:
Hi Mark,
Stein
Subject: AeroElectric-List: Re: Thread Lacing Tape
Mark Curley
building Van's RV-6
echristley(at)att.net
PostPosted: Fri May 07, 2021 9:29 am    Post subject: Thread Lacing Tape Reply with quote
In my view, thread lacing is a lot of work, and limits modifications (you can sometimes squeeze another wire into a loom, but it is as hard as ty wraps).
I like these instead of ty wraps.
https://www.homedepot.com/p/VELCRO-Brand-8-in-x-1-2-in-Reusable-Ties-50-Pack-90924HD/202261940
To see if they are up to the job, use one to tie a wire to a 1/2" tube, then see if you can do a chin-up on the wire.
On Friday, May 7, 2021, 10:11:27 AM EDT, Mark Curley <mcurley68(at)hotmail.com> wrote:
#yiv0324448453 P {margin-top:0;margin-bottom:0;}
Mark Curley
building Van's RV-6
Michael Wynn
PostPosted: Fri May 07, 2021 9:43 am    Post subject: Thread Lacing Tape Reply with quote
Hey Mark,
I will confess to maybe doing this wrong, but I used the standard lacing tape from ACS all over my RV8. The stuff firewall forward has held up well. I use adel clamps on warm parts but the wires for the EGT and CHT and all the electrical are regular Dacron tape and I have had no issues.
Michael Wynn
Livermore, CA
RV8 Flying
RV 10 Starting the build
Michael Wynn
RV 8
San Ramon, CA
Laz
PostPosted: Fri May 07, 2021 9:52 am    Post subject: Thread Lacing Tape Reply with quote
How much do you need.  I have a roll and can send you some .  It’s hard to find but I got lucky and found a spool,
Call or text me
4195735043
On Fri, May 7, 2021 at 1:33 PM Ernest Christley <echristley(at)att.net (echristley(at)att.net)> wrote:
On Friday, May 7, 2021, 10:11:27 AM EDT, Mark Curley <mcurley68(at)hotmail.com (mcurley68(at)hotmail.com)> wrote:
Mark Curley
building Van's RV-6
neal.george(at)gmail.com
PostPosted: Fri May 07, 2021 5:41 pm    Post subject: Thread Lacing Tape Reply with quote
I use TechFlex lacing with good results.
They offer many styles and finishes. What I have is not waxed, but has a finish treatment that is ever so slightly tacky. The package is long gone, and there is no ID that I can find on the spool. I found their tech support staff very helpful in selecting the tape.
Neal George
George Aviation
850-218-2939
On May 7, 2021, at 12:15 PM, Matthew S. Whiting <m.whiting(at)frontier.com (m.whiting(at)frontier.com)> wrote:
It’s not cheap and I have yet to find a place to buy small quantities.https://www.digikey.com/catalog/en/partgroup/tech-lace-series-nomex/35160
PostPosted: Sat May 08, 2021 7:37 am    Post subject: Thread Lacing Tape Reply with quote
At 12:42 PM 5/7/2021, you wrote:
Hey Mark,
. . . your experience echoes string tie practice at
the spam-can factories too. Don't recall ever
seeing anything more exotic than Type II
(Dacron) around the factory or experimental hangar.
The Dacron lace has been around since the 60's.
The Mil-T43435 spec got it's first UPDATE to
revision A and 1969!
Here's a chart that speaks to the various iterations
of M43435 lace:
https://tinyurl.com/ydottlf9
Size 3 was the most popular where I worked.
Size 2 would work for you well especially if
you can get a 'deal' on a partial or surplus
spool.
It has been used under the cowl on hundreds
of thousands of GA aircraft . . .who knows
how many transport/military machines. It's
rated for service at up to 177C (350F).
Nothing, short of directly radiated energy
from an exhaust stack, will get anywhere near
that warm.
Learn how to tie good knots:
http://aeroelectric.com/articles/cable_lace/cable_lace.html
An enhanced method 1 calls for converting
the clove-hitch into a single or double
pass constrictor knot . . . but the clove hitch
works well too.
Here is one source:
https://tinyurl.com/ydta87er
Yeah, I know it's breathtakingly expensive . . .
after all . . . it's just fancy kite string . . .
right?
Trust me, return on investment is huge.
It will take some real time experience in
the shop but by the time you go through the
first 500 yards of the 1500 yard spool, it
will have paid for itself several times over
in labor/materials costs of alternatives.
Keep an eye out on eBay. Full or partial spools
show up there from time to time. That's where
I think I got most of my inventory.
out of that stuff?"
PostPosted: Sat May 08, 2021 8:01 am    Post subject: Thread Lacing Tape Reply with quote
On Fri, May 7, 2021 at 1:33 PM Ernest Christley <echristley(at)att.net (echristley(at)att.net)> wrote: In my view, thread lacing is a lot of work, and limits modifications (you can sometimes squeeze another wire into a loom, but it is as hard as ty wraps).
I presume your referring to the running lace technique
popular Wwwaaaayyyy back when.
https://tinyurl.com/yh94ktzb
This is not recommended.
I like these instead of ty wraps. https://www.homedepot.com/p/VELCRO-Brand-8-in-x-1-2-in-Reusable-Ties-50-Pack-90924HD/202261940
Strength is but ONE issue. What's the service life
of these devices in the aircraft environment? Are
you offering to the the 'beta tester' for this
technology?
I would use these things to hold stuff together
during fabrication and even for some early
flight testing. But then I'd replace with
string ties.
By the way, got my tongue tangled around my eyeteeth
and couldn't see what I was saying. The standard
put-up for M43435 lacing tape is 500 yards, not
1500.
Found this offering for polyester lacing tape
on Amazon:
https://tinyurl.com/4fp4n33f
Bet a dollar to a donut that this is the same stuff
put up on larger spools and 'certified'. I've
ordered a spool to get a hands-on look-see. Watch
this space. Quantity and price is attractive. The ad
doesn't speak to dimensions of the lace . . . I'll
check it out.
out of that stuff?"
Voyager
PostPosted: Sat May 08, 2021 8:36 am    Post subject: Thread Lacing Tape Reply with quote
Running lace is not recommended? Really??
Better tell NASA…
https://www.sandman.com/files/NASAcable%20lacing40-43.pdf
On May 8, 2021, at 12:05 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
technology?
string ties.
1500.
on Amazon:
check it out.
out of that stuff?"
PostPosted: Sat May 08, 2021 11:49 am    Post subject: Thread Lacing Tape Reply with quote
Better tell NASA…
Okay, what does it do for you that periodic
ties don't?
I think it's a cost/benefit ratio thing.
It looks cool but does it add to the
longevity, maintainabilty or performance
of the finished product?
out of that stuff?"
Voyager
PostPosted: Sat May 08, 2021 12:25 pm    Post subject: Thread Lacing Tape Reply with quote
There is no functional difference, but there is an installation difference. For runs of any length, a running lace is 2-3 times faster to install while providing the same level of functionality. I can tie 3 running ties in the time required to tie and cut one spot tie. That is the main difference I see.
I will turn your question around: why use spot ties when a running lace is three times faster with equal functionality?
On May 8, 2021, at 3:51 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Better tell NASA…
ties don't?
out of that stuff?"
PostPosted: Sat May 08, 2021 2:20 pm    Post subject: Thread Lacing Tape Reply with quote
On Saturday, May 8, 2021, 12:02:38 PM EDT, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
technology?
I've got some wires tied up in an airplane that have been there for years. Going back in to make modifications, the hardest part was finding the end of the velcro so that I could get the "unwrap" started. Just as strong as when I put them on.
PostPosted: Sun May 09, 2021 10:11 am    Post subject: Thread Lacing Tape Reply with quote
Good data point! Are your examples the
same product as above? I note that the
product cited is 1/2 x 8" . . . can you
cut them into smaller segments? 8" seems
like a LOT of stuff to wrap around a few
wires.
out of that stuff?"
PostPosted: Sun May 09, 2021 4:23 pm    Post subject: Thread Lacing Tape Reply with quote
Doing a running lace is an acquired skill
if you're going to secure each 'loop'
around the bundle. Lacking such security,
a break in the lace run will relax many
loops around the bundle. Further, you have to work
with as long a hunk of lace as you can
manage without tangling . . . generally
2x your 'reach'.
Individual ties of string or tie-wraps have
been standard operating technique for every
airframe company I've worked for.
out of that stuff?"
art(at)zemon.name
PostPosted: Sun May 09, 2021 6:47 pm    Post subject: Thread Lacing Tape Reply with quote
Folks,
I'll chime in here, too. I used both lacing and Velcro ties in my airplane, on the cold side of the firewall. I laced the long runs of bundles of wires that I fabricated prior to installing them in the airplane. I used the lacing tape from Aircraft Spruce and made a little video on how I did it. No, it's not NASA spec but it's secure. I did have to remove the lacing from a couple of bundles and, believe me, it's secure!
Inside the cabin and behind the panel, I used the thin Velcro ties that Bob linked to. I like these because they are very thin and flexible so they are easy to use, even when you only have a few wires to tie up. I'm not worried about longevity. Name-brand Velcro has been around a long time so I trust the material. Furthermore, it's a low-risk application. If they start to deteriorate, I'll notice during the annual inspections and I can replace them. These ties are only securing bundles of wire, not heavy components which hold the airplane together.
On the hot side of the firewall, I used the normal heat tolerant stuff: zip-ties and Adel clamps.
    -- Art Z.
https://CheerfulCurmudgeon.com/Friendship is like a stone. A stone has no value, but when you rub two stones together properly, sparks of fire emerge.
Rabbi Mordechai of Lechovitz
PostPosted: Sun May 09, 2021 7:15 pm    Post subject: Thread Lacing Tape Reply with quote
At 09:46 PM 5/9/2021, you wrote:
Folks,
On the hot side of the firewall, I used the normal heat tolerant stuff: zip-ties and Adel clamps.Â
Good data sir, thank you.
out of that stuff?"
bobnoffs
PostPosted: Mon May 10, 2021 3:03 am    Post subject: Thread Lacing Tape Reply with quote
fwiw , when i started using it 20 yrs. ago the breaking strength was 80 lbs. . plenty for what  i wanted.
On Sun, May 9, 2021 at 10:18 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Folks,
  out of that stuff?"
Voyager
PostPosted: Mon May 10, 2021 3:40 am    Post subject: Thread Lacing Tape Reply with quote
Art,
I went to look at your video and found it was one I had already watched. 😁
I likely will do a hybrid approach on my S-21 as well. I will probably lace the fuselage runs since they are long and straight and I don’t believe they go through grommets, but I don’t remember what RANS recommends there.
The wing wires go through grommets in the ribs so I probably will spot tie those 3-4 times between each rib. A running lace going through grommets would be a nuisance.
I also plan to spot tie behind the panel as the runs will be short with many loops and branches. I have small velcro cord organizers made for charging cords and will use those as temporary organizers as I run the wires. However, I plan to replace all velcro with spot ties once I am done. Velcro just screams “amateur” to me, and yes, I realize I am building an experimental - amateur built airplane. However, as a retired EE, I don’t want my electrical system to scream amateur to everyone who sees it.
In front of the firewall, I will use Adel clamps and zip ties very sparingly.  Even though zip ties are easy to use and easy to remove and used widely in the auto world, I just don’t like them. They just scream “mass produced” to me.
The nice thing about E-AB, is that we all get to choose our solutions and honor our biases.  Cheers.
Matt
On May 9, 2021, at 10:53 PM, Art Zemon <art(at)zemon.name> wrote:
Folks,
-- Art Z.
art(at)zemon.name
PostPosted: Mon May 10, 2021 4:13 am    Post subject: Thread Lacing Tape Reply with quote
Matt,
It sounds like your plane will be gorgeous and exude the Professional Look. Hopefully I'll get to see it at Oshkosh one of these years. I was more interested in getting my plane safely into the air so I took the expedient path. Now I am planning to redo the panel and rewire that end of the plane, because I don't like how it looks. C'est la vie.
    -- Art Z.
On Mon, May 10, 2021 at 6:52 AM Matthew S. Whiting <m.whiting(at)frontier.com (m.whiting(at)frontier.com)> wrote:
Art,
Matt
On May 9, 2021, at 10:53 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
    -- Art Z.
Goto page 1, 2  Next
Page 1 of 2
