Contactor Questions
A Lumley
PostPosted: Thu May 13, 2021 11:10 am    Post subject: Contactor Questions Reply with quote
Good afternoon,
I'm working on a schematic for my RV-10 based on the Z-101 architecture and have come up with a couple questions about contactors...
First, about the starter contactor. The Z-101 shows a single conductor connecting the contactor to the starter with a jumper at the starter. I found another discussion from 2015 with an alternative arrangement (attached) for permanent magnet starters. I'm planning to use a B&C starter. Should I be using the extra wire & diode?
Second, I'm adding an external power outlet per Z-31A. I've made sense of most of this drawing but I'm unsure why there is no diode shown across the coil in the Z-31A diagram? The B&C continuous contactor includes an external diode already. Should it be removed?
Thanks for taking the time to read my perhaps basic questions!
 Filesize:  68.33 KB
 Viewed:  4208 Time(s)
 Filesize:  46.57 KB
PostPosted: Thu May 13, 2021 3:57 pm    Post subject: Re: Contactor Questions Reply with quote
Z-31A does not require a diode because the over-voltage module provides arc suppression.
No, do not remove the B&C installed diode. It does not hurt anything.
Joe Gores
PostPosted: Thu May 13, 2021 7:31 pm    Post subject: Contactor Questions Reply with quote
At 02:10 PM 5/13/2021, you wrote:
--> AeroElectric-List message posted by: "A Lumley" <andrew.lumley(at)sympatico.ca>
Good afternoon,
By 'extra wire' are you talking about the jumper from
contactor "I" terminal to the starter's "S"
terminal? Yes, wire as shown and including
the diode is a good thing. The starter contactor
from B*C will include a built in diode on its
coil.
Wouldn't hurt but not necessary assuming you
can get a B*C crowbar ov module. Are those
available? I though those were out of production.
That's what this organization is here for
my friend . . . folks that already know everything
don't need us!
out of that stuff?"
A Lumley
PostPosted: Thu May 13, 2021 7:42 pm    Post subject: Re: Contactor Questions Reply with quote
Thanks to you both for the quick feedback. I'll include the jumper from the contactor "I" terminal to the starter with the extra diode.
You are correct that B&C no longer sells the crowbar module so I was going to build my own from your crowbar schematics.
Thanks again, I'm sure I'll have lots more questions...
