Compressor charging
Goto page Previous  1, 2
stephen.hayne
PostPosted: Wed Aug 04, 2021 12:22 pm    Post subject: Re: Compressor charging Reply with quote
I agree that the "pooling" of the drool is now further than the snot bottle - but, I argue that the line and components are all SS, except for a brass elbow+union (perhaps better than the stock snot bottle?), and is purged every flight, sometimes during the flight.
Working nicely so far and saves getting my pants and shoes sprayed when the wind is just wrong. Smile
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp
stephen.hayne
PostPosted: Wed Aug 04, 2021 12:37 pm    Post subject: Re: Compressor charging Reply with quote
Ttail wrote:
Stephen, when you action your snot valve in the cockpit, what do you see on your Main Air gauge ... I mean what happens ?
Nothing happens - the check valve is upstream, so all pressure is kept in the system. I have noticed that after about 20 minutes with the relief valve open, my bottle/system pressure comes down from 45 to 42. Thus, I have some leak at high pressure. When hangared, and bottle valve closed, it take 2+ days to bleed down, so system is pretty tight at low(er) pressures. Hope the airplane can't read, because sure enough, now I've jinxed it.
443LM Nanchang CJA
Page 2 of 2
