Garmin GTR 200 Help Needed
farmrjohn
PostPosted: Fri Jun 11, 2021 3:14 pm    Post subject: Garmin GTR 200 Help Needed Reply with quote
I have a GTR 200 installed in a certificated airplane so Garmin tech support won't help. I'm having an issue with the received volume on the initial response to my transmission in that the volume is about 1/2 of normal, and it only is in the left headset speaker. Either this has recently started or I haven't noticed it before. The radio is stand alone, no audio panel is installed. Garmin says take it to a dealer but there aren't any conveniently located. Any ideas? John
farmrjohn
PostPosted: Sat Jun 12, 2021 3:00 pm    Post subject: Re: Garmin GTR 200 Help Needed Reply with quote
Update-I used the headset and mike switch from the passenger side and all was normal. However, I didn't not swap headsets and will try that next. Both headsets are the same make and model, non-noise reducing style.
