wrk2win4u
Posted: Fri Jun 18, 2021 12:03 pm Post subject: Tailwheel |
Hi List,
I have a Mark III classic with a Rotax 912 UL. I want to put on an Aviation Products 6" tailwheel on because some of my takeoffs and landings are off runway, gravel, dirt & grass. I currently have a 4" tailwheel made by Aviation Products that weighs 2 lbs. 12.3oz. The new 6" tailwheel weighs 4 lbs. 8.1 oz.
Have any Mark III Classic owners changed to the larger / softer tailwheel? If so, has it been an improvement over the 4-inch wheel? Is there a reason NOT to make the change?
Kurt
Kolb Mark III Classic
Rotax 912UL
Jerry-TS-MkII
Posted: Fri Jun 18, 2021 12:52 pm Post subject: Tailwheel |
Two extra pounds hanging that far back will likely change your weight
and balance significantly. Tail heavy is never good! Or as they say,
"if at first you don't succeed.. tail heavy is not for you.."
On 2021-06-18 4:03 pm, K I wrote:
| Quote: | Hi List,
Kurt
Rotax 912UL
twoflyboys(at)aol.com Guest
Posted: Fri Jun 18, 2021 4:19 pm Post subject: Tailwheel |
I did something like that on my firestar 1. I had to take it off after one flight and it only weighed like 3lbs
Very dangerous
Salvador
| Quote: | On Jun 18, 2021, at 3:52 PM, 1957grnchev(at)bluemarble.net wrote:
Two extra pounds hanging that far back will likely change your weight and balance significantly. Tail heavy is never good! Or as they say, "if at first you don't succeed.. tail heavy is not for you.."
> Hi List,
> Kurt
> Rotax 912UL
