Fueling tanks way in the back.....
Charlie Mike
PostPosted: Wed Jun 16, 2021 3:56 pm    Post subject: Fueling tanks way in the back..... Reply with quote
Does anyone have a trick or tactic to fueling the in tandem 5 gal tanks, behind the rear seat? Its a tight squeeze with a gas can......
Kolb Slingshot 582, C gearbox.
stuart(at)harnerfarm.net
PostPosted: Wed Jun 16, 2021 4:28 pm    Post subject: Fueling tanks way in the back..... Reply with quote
This is what I use for the firefly. Will transfer 5 gal. in about 2 minutes.
Works best if you can get the can close to the same level as the tank.
https://www.ebay.com/itm/274706912240?epid=836036450&hash=item3ff5ced3f0:g:z
HgAAOSw7GpgQP75
neilsenrm(at)gmail.com
PostPosted: Wed Jun 16, 2021 6:13 pm    Post subject: Fueling tanks way in the back..... Reply with quote
John W used to have a fueling tube made from maybe 1.5" PVC for his Kolbra. One end had a 90 degree elbow pointing up and one on the other end down. He would take the cap off the rear tank and put the down elbow into the tank and pour fuel into the elbow pointing up. The down elbow may have had a 2-3" extension and the up elbow a larger diameter pipe adapter. It seemed to work well.
Rick Neilsen
Redrive VW powered MKIIIC
On Wed, Jun 16, 2021 at 7:58 PM Charlie Mike <Chuckmiranda8(at)gmail.com (Chuckmiranda8(at)gmail.com)> wrote:
--> Kolb-List message posted by: "Charlie Mike" <Chuckmiranda8(at)gmail.com (Chuckmiranda8(at)gmail.com)>
Kolb Slingshot 582, E gearbox.
http://forums.matronics.com/viewtopic.php?p=502398#502398
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
mojavjoe
PostPosted: Wed Jun 16, 2021 8:01 pm    Post subject: Fueling tanks way in the back..... Reply with quote
harber fright has a battery powered gas pump for about $10.00. works fine for me.
Rick Neilsen
On Wed, Jun 16, 2021 at 7:58 PM Charlie Mike < Chuckmiranda8(at)gmail.com (Chuckmiranda8(at)gmail.com)> wrote:
--> Kolb-List message posted by: "Charlie Mike" < Chuckmiranda8(at)gmail.com (Chuckmiranda8(at)gmail.com)>
FORUMS -
WIKI -
b Site -
Charlie Mike
PostPosted: Wed Jun 16, 2021 8:37 pm    Post subject: Re: Fueling tanks way in the back..... Reply with quote
Thanks fellas! I’m looking at the battery powered fuel pumps now.
Hopefully I will have this project flying soon….
wrk2win4u
PostPosted: Wed Jun 16, 2021 9:06 pm    Post subject: Fueling tanks way in the back..... Reply with quote
Yes, I bought a handheld fuel pump powered by two AA batteries. They’re for sale on Amazon for approximately $16. The base goes into the gas can and a 2 foot hose goes into the plastic tank top.
Kurt
Kolb MKIII
[quote] On Jun 16, 2021, at 18:30, Stuart Harner <stuart(at)harnerfarm.net> wrote:
HgAAOSw7GpgQP75
Richard Pike
PostPosted: Thu Jun 17, 2021 4:55 am    Post subject: Re: Fueling tanks way in the back..... Reply with quote
This one has a 10' long hose, reaches the wing on the MKIII. Pumps about 2 gallons/minute.
https://www.amazon.com/TERA-PUMP-TREP01-TXL-Multi-Purpose-Transfer/dp/B083QSHP7V/ref=sr_1_2?dchild=1&keywords=tera+pump+long+hose&qid=1623934435&s=automotive&sr=1-2
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Charlie Mike
PostPosted: Thu Jun 17, 2021 11:21 am    Post subject: Re: Fueling tanks way in the back..... Reply with quote
I like that one….
