Coop85
Posted: Sat Sep 18, 2021 8:19 am Post subject: Strobe power supply |
David, I found a Whelen power supply on eBay for a great price yesterday so am going to give that a try.
Lew, Interesting point on powering up after sitting. I take it you connected the resistor (headlight) in series with the power line to the strobe power supply? Probably the only option but just wanted to confirm.
Thanks again,
Marcus
| Quote: | On Sep 18, 2021, at 11:01, Lew Gallagher <lewgall(at)charter.net> wrote:
 I also have a Whelen system sitting for years, and thought I'd pass along ,just in case someone wants to plug yours in, I had read long ago that it is advisable to put a big resistor in line when first powering it up after the big sleep. That keeps the completely discharged capacitors from blowing? I put an auto headlight bulb in line on first powerup and watched it go from bright to dim to off in a few seconds. The power supply was fine - couldn't hurt. Later, - Lew
On 9/18/2021 10:35:12 AM, dlm <dlm34077(at)gmail.com> wrote:I have a Whelen system that was working when removed, aging in my hangar; I replaced mine with an LED system. I have the whole system including lights , bulbs and power supply, no wiring.
David McNeill
4806264048
On Fri, Sep 17, 2021 at 11:50 PM RV10-List Digest Server <rv10-list(at)matronics.com (rv10-list(at)matronics.com)> wrote:
| Quote: | *
Today's complete RV10-List Digest can also be found in either of the
of the RV10-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2021-09-17&Archive=RV10
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2021-09-17&Archive=RV10
RV10-List Digest Archive
Total Messages Posted Fri 09/17/21: 7
Today's Message Index:
1. 07:18 AM - G100UL (Kelly McMullen)
2. 08:04 AM - Re: G100UL (Charlie England)
3. 08:30 AM - Re: G100UL (Kelly McMullen)
4. 11:38 AM - Re: G100UL (dave(at)corwith.com (dave(at)corwith.com))
5. 01:17 PM - Strobe Power Supply Replacement (Marcus Cooper)
6. 02:05 PM - Re: Strobe Power Supply Replacement (Lenny Iszak)
7. 02:37 PM - Re: Strobe Power Supply Replacement (Marcus Cooper)
________________________________ Message 1 _____________________________________
Time: 07:18:42 AM PST US
From: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
Subject: G100UL
Having just watched the AOPA webinar on the implementation of making this
fuel available, the one area not addressed is whether amateur built
experimental aircraft would need to do any paperwork to use the fuel. Type
certificated aircraft will require an STC, just like they do for using
mogas. Seems to me that we could just change our fuel placards to read
G100UL or 100LL required, and start using it. Would be interesting to get
EAA's opinion on this from one of their legal and technical experts.
If we don't need anything, it would reduce GAMI's potential income a bit,
although they still will get licensing/patent fees anyway.
There is no question in my mind that any IO-540 that is currently installed
in a -10 and runs satisfactorily on 100LL will be fine on G100UL.
Especially since the stock engine was originally certified on 91/96 Avgas.
Kelly
________________________________ Message 2 _____________________________________
Time: 08:04:42 AM PST US
Subject: Re: G100UL
From: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
> this fuel available, the one area not addressed is whether amateur
> built experimental aircraft would need to do any paperwork to use the
> fuel. Type certificated aircraft will require an STC, just like they
> do for using mogas. Seems to me that we could just change our fuel
> placards to read G100UL or 100LL required, and start using it. Would
> be interesting to get EAA's opinion on this from one of their legal
> bit, although they still will get licensing/patent fees anyway.
> installed in a -10 and runs satisfactorily on 100LL will be fine on
> G100UL.
> Kelly
I've never heard of any rule preventing homebuilts from running any fuel
they want. No STC is required for a homebuilt. I've run 100LL, 93 E-free
mogas, and 93 E-gas in homebuilts, and I know of quite a few others who
run all variations too, down to 87 E-gas (in Mazda rotaries). I'm not
saying it's smart to run 87 in a 10-1 compression angle valve engine;
just that it isn't illegal.
It should be relatively easy to get EAA's opinion; just ask.
Charlie
________________________________ Message 3 _____________________________________
Time: 08:30:49 AM PST US
Subject: Re: G100UL
From: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
I agree with you, although I have heard of FBOs that won't pump into a
tank that doesn't have a placard allowing a specific grade of fuel..easy
to fix with label maker. I would especially look forward to less
maintenance in terms of fouled plugs, oil change intervals, etc.
Kelly
> Charlie
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon>
> Virus-free. www.avast.com
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link>
> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
________________________________ Message 4 _____________________________________
Time: 11:38:44 AM PST US
Subject: Re: G100UL
Just read the article in AOPA magazine. It states that the stc funds the
development. About 1.50=24/hp i think. So a one time fee of 400-600=24 ge
ts u a sticker. Not sure how expermental fits in
Dave
Sent with a=C2-Spark
On Sep 17, 2021, 11:07 -0400, Charlie England <ceengland7=40gmail.com>, w
rote:
this fuel available, the one area not addressed is whether amateur built
e certificated aircraft will require an STC, just like they do for using
mogas. Seems to me that we could just change our fuel placards to read G1
00UL or 100LL required, and start using it. Would be interesting to get E
talled in a -10 and runs satisfactorily on 100LL will be fine on G100UL.
vgas.
> > Kelly
l they want. No STC is required for a homebuilt. I've run 100LL, 93 E-fre
e mogas, and 93 E-gas in homebuilts, and I know of quite a few others who
run all variations too, down to 87 E-gas (in Mazda rotaries). I'm not sa
ying it's smart to run 87 in a 10-1 compression angle valve engine; just
> Charlie
________________________________ Message 5 _____________________________________
Time: 01:17:26 PM PST US
From: Marcus Cooper <cooprv7(at)yahoo.com (cooprv7(at)yahoo.com)>
Subject: Strobe Power Supply Replacement
I have a Strobes N More Pro 606 power supply driving my strobe lights and it has
been working great, but the power supply connector has become loose after 16
years and is intermittent. I'm not sure I can repair it so am looking for an
alternative and it appears the model I have is no longer produced. I saw another
by Preco that looks EXTREMELY similar to what I have, right down to the caution
verbiage. I was wondering if anyone has any experience with these or other
recommendations?
Marcus
________________________________ Message 6 _____________________________________
Time: 02:05:12 PM PST US
From: Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
Subject: Re: Strobe Power Supply Replacement
I=99m using these LED strobes, the older v2 version, and they=99
ve been great. They fit the cutout of the Xenon bulbs you have.
https://www.strobesnmore.com/feniex-cannon-v3-hide-away.html
<https://www.strobesnmore.com/feniex-cannon-v3-hide-away.html>
Lenny
> On Sep 17, 2021, at 4:17 PM, Marcus Cooper <cooprv7(at)yahoo.com (cooprv7(at)yahoo.com)> wrote:
and it has been working great, but the power supply connector has become
loose after 16 years and is intermittent. I'm not sure I can repair it
so am looking for an alternative and it appears the model I have is no
longer produced. I saw another by Preco that looks EXTREMELY similar to
what I have, right down to the caution verbiage. I was wondering if
anyone has any experience with these or other recommendations?
> Thanks,
> Marcus
________________________________ Message 7 _____________________________________
Time: 02:37:39 PM PST US
Those are really neat! I=99m mostly looking for a new power supply, bu
t these may very well be in my future.
Marcus
> On Sep 17, 2021, at 17:19, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
> =EF=BBI=99m using these LED strobes, the older v2 version, and th
ey=99ve been great. They fit the cutout of the Xenon bulbs you have.
> Lenny
it has been working great, but the power supply connector has become loose a
fter 16 years and is intermittent. I'm not sure I can repair it so am lookin
g for an alternative and it appears the model I have is no longer produced. I
saw another by Preco that looks EXTREMELY similar to what I have, right dow
n to the caution verbiage. I was wondering if anyone has any experience with
>> Thanks,
>> Marcus
WIKI -
_________________ Marcus Cooper
RV-10 since 2006 |
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Sat Sep 18, 2021 2:36 pm Post subject: Strobe power supply |
Correct.
On 9/18/2021 12:21:48 PM, Marcus Cooper <cooprv7(at)yahoo.com> wrote:Thanks,
Thanks again,
Marcus
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
