Main Power Routing RV8
Drum
PostPosted: Fri Sep 24, 2021 4:05 am    Post subject: Main Power Routing RV8 Reply with quote
Hi - I’m building RV8 with aft battery placement. From the battery contactor I run 2AWG to a terminal block near panel where a buss bar connects main power to main buss and some aux busses.
I am planning to run a 2AWG from same post where main power comes into terminal block to the hot side of the starter contactor.
My would have preferred to run directly to starter contactor but I don’t want to lengthen the run with a backtrack from starter contactor to terminal block and the busses off the terminal block - weight complexity and voltage drop reasons.
Are there compelling reasons not to break the main power wire at terminal block with aft battery placement?
Thanks in advance.
Warm regards,
 Filesize:  248.09 KB
 Viewed:  2170 Time(s)
 Filesize:  354.75 KB
Drum G
RV8 - Firewall Forward
Holly Hill, SC
