MJKTuck(at)cs.com Guest
Posted: Wed Oct 13, 2021 2:31 pm Post subject: New ignition modules |
Hi guys,
After some hit and miss starting, I finally gave in and bought two new
ignition modules which I installed today.
Engine burst into life immediately upon starting.
The only problem is that when I do a 'mag' check, the engine runs fine
on one 'mag/module' but the engine stops when I switch to the other.
I will recheck my wiring of course particularly yellow and white wires
to the ignition coils (which I had to think about which was which but
I'm pretty sure I got them going to the correct white wires coming out
of the coils).
I have the 'old style' 4-pin plug modules.
I'm open to ideas on what else I might check.
regards,
Martin Tuck
N152MT
Wichita, KS
SteveIvell(at)pestproof.c Guest
Posted: Wed Oct 13, 2021 2:57 pm Post subject: New ignition modules |
Definitely a wiring problem....unless the new module is duff. Earth problems are a favorite......maybe try switching around the modules and see if it replicates. Good Luck
Kind Regards
Steve Ivell
GSTES
Mob: 07971 128842
E-mail: steveivell(at)pestproof.co.uk
spcialeffects
Posted: Thu Oct 14, 2021 2:39 am Post subject: Re: New ignition modules |
Hi Martin. I have the same 4 pin modules and had a similar problem. When I changed to one of the circuits my 914 ran rough. I bought the new ignitech modules and still had the same issue. The only way I rectified it was to buy new rotax modules. What I did find out during my investigations was that the ignition modules are wired up to the coils differently for a rotax 912 then a 914. On a 912 A module runs 2 upper and 2 lower plugs but on the 914 module A runs all the top plugs and B runs all the bottom.
tennant
Posted: Thu Oct 14, 2021 10:35 am Post subject: Re: New ignition modules |
Martin,
I had the same problem. Bought expensive new modules and after a lot of messing about - it was the stator that was defective!!
Barry
_________________ Barry Tennant
D-EHBT
At EDLM - Germany |
peter.rees01(at)tiscali.c Guest
Posted: Thu Oct 14, 2021 11:22 am Post subject: New ignition modules |
Swap the red wires over - if the problem changes from L to R (or R to L) - stator fault. Also try the same on the pickups.
Process of Elimination
Peter
| Quote: | On 14 Oct 2021, at 19:42, tennant <barrington.tennant(at)gmail.com> wrote:
Martin,
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
http://forums.matronics.com/viewtopic.php?p=503524#503524
Posted: Thu Oct 14, 2021 2:15 pm Post subject: New ignition modules |
Me too ...except it was the ground wire
Will
William Daniell
LONGPORT
+1 786 878 0246
On Thu, Oct 14, 2021 at 2:39 PM tennant <barrington.tennant(at)gmail.com (barrington.tennant(at)gmail.com)> wrote:
| Quote: | --> Europa-List message posted by: "tennant" <barrington.tennant(at)gmail.com (barrington.tennant(at)gmail.com)>
Martin,
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
