ptag.dev(at)talktalk.net Guest
Posted: Thu Oct 28, 2021 9:10 am Post subject: Mod 53 |
Hi! Brian ,
If Mod 53 was my long range tank mod. The issue that was originally thrown up was the exit pipe should have a finger filter fitted.
Bob Harrison EX G-PTAG.
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Brian Davies
Sent: 29 September 2021 11:06
To: Europa-List(at)Matronics. Com <europa-list(at)matronics.com>
Subject: Re: Mod 53
For UK owners, I am not sure the LAA ever approved the use of the Mod 53 Long Range Tank Mod. Francis had some issue with it that I have forgotten. It is not listed as an approved manufacturer mod in the current TADS. I still have a brand new/unused tank - open to offers!
Brian Davies
On Wed, Sep 29, 2021 at 10:49 AM <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
I fitted it on my plane and used it on various long distant trips including the Dawn to dusk Challenge I did with my son (newly diagnosed with MND/ALS ) back in 2010, where we visited all 119 islands named on the UK 1/2 mill charts and covered a bit over 1700nm in a day at speed with 3 stops. Worked perfectly.
David Joyce, GXSDJ
On 2021-09-29 02:13, William McClellan wrote:
Posted: Thu Oct 28, 2021 9:22 am Post subject: Mod 53 |
Hi! William,
My Suggestion on these issues is to fix an electric transfer pump . How sick would you be ( or deadly unpleased !) to run out of fuel and still have a supply in the blessed Long Range Tank ? ( except you can't hear it so don’t forget to switch it off when empty !)
Bob Harrison EX G-PTAG .
budyerly@msn.com
Posted: Sun Oct 31, 2021 1:06 pm Post subject: Re: Mod 53 |
Seems to me if you are pumping into the main tank anyway, fitting another filter would not serve a great purpose other than being the department of redundant redundancy.
It would however prevent damage to a aux tank pump. Depending on how fine the filter is or how clogged it would effect the siphon as well.
Intersting experimental experiment.
Best Regards,
Bud Yerly
budyerly@msn.com
Posted: Sun Oct 31, 2021 1:07 pm Post subject: Re: Mod 53 |
Best Regards,
Bud Yerly
