budyerly@msn.com
Posted: Sun Oct 31, 2021 1:38 pm Post subject: TLR46A for Windows 7-10 Load |
For those of you with a 914 that was upgraded to TCU P/N 966741 using the latest TLR46A, DOSBox, FTDI USB to Serial combination who may not have been able to load this program I may have a solution for you.
The web was full of owners trying to get the program to work with Windows 7 or 10. Luckily a software pro was able to light a fire in my solution attempts. His explanation was a bit brief and all I did was add detail for those of us not blessed with the patience to read code or understand program execution. (I'm just one of the monkies in a room full of typewriters trying to code programs or adapt program execution files.) I finally made a breakthrough. Attached is a pdf paper on my program execution steps and changes to files to assure the programs work together.
For those with the older TLR 4.3 or 4.5 I'm sorry, as you still are limited in needing a Rotax dongle to monitor/set throttle on your 914 TCU.
Best Regards,
Bud Yerly
 Download |
| Filename: |
TLR 46 Load Windows 7-10 Yerly.pdf |
1.54 MB |
| Downloaded: |
549 Time(s) |
