docclv(at)windstream.net Guest
Posted: Thu Oct 21, 2021 10:44 am Post subject: Duplicate ACS keys |
Phil: Can a guy order ANY ACS numbered key from ACS even though the key
in question is not on the key's number list that Aircraft Spruce has?
How do you place an order for a key to ACS? I can't get them to even
reply. Doc
digidocs
Posted: Thu Oct 21, 2021 10:54 am Post subject: Duplicate ACS keys |
If you need a copy, I've found the local locksmith can make them.
On Thu, Oct 21, 2021 at 1:47 PM Doc <docclv(at)windstream.net (docclv(at)windstream.net)> wrote:
| Quote: | --> RV10-List message posted by: Doc <docclv(at)windstream.net (docclv(at)windstream.net)>
reply. Doc
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
philperry9
Posted: Thu Oct 21, 2021 11:05 am Post subject: Duplicate ACS keys |
Just order this key… (double cut so it’s more hassle-fee when you insert it. I also got the rubber boot option to soften the edges of the key.)
https://www.aircraftspruce.com/catalog/elpages/igswitcheskey.php?clickkey=10386
At the time of checkout, you’ll be prompted to enter the key code from your existing key.
Pretty easy.
Phil
| Quote: | On Oct 21, 2021, at 1:58 PM, David Carr <junk(at)dcarr.org> wrote:
reply. Doc
FORUMS -
WIKI -
b Site -
Posted: Thu Oct 21, 2021 12:42 pm Post subject: Duplicate ACS keys |
Guys
If you are talking about those ACS keys for the keyed ignition switch or for the aircraft doors, they can be duplicated in any neighbourhood locksmith.
Carlos
Enviado do meu iPhone
| Quote: | No dia 21/10/2021, às 19:50, Doc <docclv(at)windstream.net> escreveu:
Phil: Can a guy order ANY ACS numbered key from ACS even though the key in question is not on the key's number list that Aircraft Spruce has? How do you place an order for a key to ACS? I can't get them to even reply. Doc
