Canvas Cover
genie(at)swissmail.org
PostPosted: Mon Nov 15, 2021 11:37 pm    Post subject: Canvas Cover Reply with quote
Does anyone know what kind of material is used for the canvas cover of
Kitfoxes and Avid Flyers? Is it Ceconite?
I am asking because I have found small holes in my aircraft and would
like to patch them up.
Thanks.
George Nielsen
Avid Flyer I-6640
kitfox(at)mcn.org
PostPosted: Mon Nov 15, 2021 11:52 pm    Post subject: Canvas Cover Reply with quote
Hi George,
Mine was Ceconite (1992 Kitfox Model 4) which used the Stitts Poly Fiber system for adhesive and cover.
I think Stitts and Ceconite are similar. Flew it today, about 525 hours on Subaru EA81.
I f you're going to use Stitts covering, I would recommend Poly Tone paint as it is easy to patch and repair.
I used System 3 paint and its very hard to patch properly.
Kirby Cramer
Kitfox 4 NSI Subaru, N45KC
Vans RV7A O-360, N445KC
FAA Experimental Aircraft Repairman
EAA Life Member
26 Rollingview Lane Fallbrook, CA 92028
KirbyCramer(at)gmail.com
760-505-3173
YouTube: Cramer's Classic Cycles
michaelgibbs(at)cox.net
PostPosted: Tue Nov 16, 2021 7:09 am    Post subject: Canvas Cover Reply with quote
Both my Model IV and Series 7 Kitfoxes use PolyFiber.
Mike
Phoenix, AZ
[quote] On Nov 16, 2021, at 1:03 AM, Kirby Cramer <kitfox(at)mcn.org> wrote:
Hi George,
Kirby Cramer
EAA Life Member
760-505-3173
rtoth4310(at)gmail.com
PostPosted: Tue Nov 16, 2021 7:34 am    Post subject: Canvas Cover Reply with quote
Did mine with Stitts Poly Fiber and the Poly Tone paints worked great and pretty easy! Good luck!
Bob Toth
[quote] On Nov 16, 2021, at 10:14 AM, Michael Gibbs <michaelgibbs(at)cox.net> wrote:
Mike
Phoenix, AZ
> Hi George,
> Kirby Cramer
> EAA Life Member
> 760-505-3173
PostPosted: Thu Nov 18, 2021 12:43 am    Post subject: Canvas Cover Reply with quote
Hi Kirby,
Thank you for your reply. I will check if my plane uses the Stitts covering.
I see that your Kitfox makes use of a Subaru engine. Was it easy to
install? How does your Kitfox perform with this engine?
George Nielsen
Avid Flyer I-6640
The Hague, the Netherlands
On 16-Nov-21 8:52, Kirby Cramer wrote:
Hi George,
Kirby Cramer
EAA Life Member
760-505-3173
PostPosted: Thu Nov 18, 2021 12:45 am    Post subject: Canvas Cover Reply with quote
Hi Mike,
Thank you for your reply. I trust that PolyFiber is well suited for such
aircraft.
George Nielsen
Avid Flyer I-6640
Mike
Phoenix, AZ
> Hi George,
> Kirby Cramer
> EAA Life Member
> 760-505-3173
PostPosted: Thu Nov 18, 2021 12:59 am    Post subject: Canvas Cover Reply with quote
Hi Bob,
Thank you for your reply. I hope that my plane makes use of Stitts Poly
Fiber.
George Nielsen
Avid Flyer I-6640
Bob Toth
> Mike
> Phoenix, AZ
>> Hi George,
>> Kirby Cramer
>> EAA Life Member
>> 760-505-3173
kitfox(at)mcn.org
PostPosted: Thu Nov 18, 2021 10:25 am    Post subject: Canvas Cover Reply with quote
Hi George,
My Kitfox 4 flys well with the NSI EA81 Subaru.
I cruise at 95 MPH at 4000 RPM. Fuel burn is a little over 4 GPH.
I build it in 1993 and have about 535 trouble-free hours on it so far.
About 40 pounds heavier than a Rotax 912. I'm not aware of anyone making the Subaru conversion anymore.
Here is a link to a YouTube video on my motor:
https://www.youtube.com/watch?v=BPLVQ2733CQ
Kirby
Subject: Re: Canvas Cover
Hi Kirby,
I see that your Kitfox makes use of a Subaru engine. Was it easy to install? How does your Kitfox perform with this engine?
George Nielsen
Avid Flyer I-6640
Hi George,
Kirby Cramer
EAA Life Member
760-505-3173
PostPosted: Thu Nov 18, 2021 2:59 pm    Post subject: Canvas Cover Reply with quote
Nice job on the video, Kirby, thanks! I hadn’t seen it before.
Mike
Kitfox Series 7
Phoenix, AZ
[quote] On Nov 18, 2021, at 11:27 AM, Kirby Cramer <kitfox(at)mcn.org> wrote:
Hi George,
Kirby
Hi Kirby,
George Nielsen
Avid Flyer I-6640
> Hi George,
> Kirby Cramer
> EAA Life Member
> 760-505-3173
