Door Weatherstripping
Jim Combs
PostPosted: Wed Nov 17, 2021 4:49 pm    Post subject: Door Weatherstripping Reply with quote
I am 10 years in and need to replace my door weatherstripping.
Anyone wish to share what they are using (Part number / Source?)
Thanks, Jim Combs
N312F (1470 hours)
RV-10 -> N312F - Flying as of 12/2008
rjones560xl@gmail.com
PostPosted: Thu Nov 18, 2021 11:31 am    Post subject: Door Weatherstripping Reply with quote
That would depend on which method you used to do the original weatherstripping. I used the 3/8X7/32 from McMaster Car available here https://www.mcmaster.com/door-seals/water-and-weather-resistant-hollow-foam-rubber-surface-mount-seals/I left as much door frame material as possible and put this in the channel to be compressed as the door closes. Others used something like this https://www.mcmaster.com/door-seals/oil-resistant-push-on-seals-with-bulb-on-side/.
They ground away enough of the door frame to push this on the edge to give a good seal. The original choice and current fit will determine what will work as a replacement.
Robert Jones
On Nov 17, 2021, at 4:53 PM, Jim Combs <jiminlexky(at)gmail.com> wrote:
--> RV10-List message posted by: Jim Combs <jiminlexky(at)gmail.com>
Thanks, Jim Combs
N312F (========================== - The RV10-List Email====================================================; - MATRONICS WEB FORUMS -
Robert J Jones
702-521-1840
Kelly McMullen
PostPosted: Thu Nov 18, 2021 5:34 pm    Post subject: Door Weatherstripping Reply with quote
I did not modify my door frame for the Grainger seals. I got my seals from https://www.aircraftdoorseals.com/categories/vans-aircraft/rv-10.htmlCall and verify to get what you need, as the price was about double what is shown, earlier this year. Easy to install, seems to be fine so far.
On Wed, Nov 17, 2021 at 5:53 PM Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
--> RV10-List message posted by: Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)>
Thanks, Jim Combs
N312F (1470 hours)
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Mauledriver(at)nc.rr.com
PostPosted: Mon Nov 29, 2021 8:32 am    Post subject: Door Weatherstripping Reply with quote
Ten years as well and going thru the same process.  I originally used the Mcmaster 'with bulb on side' seal  so I'm replacing with same.  Some recent searches turned up some very detailed videos on how to best do this style of seal I hope to improve my original install (or not).
Completely OT: Major avionics brain upgrade from G430w to Avidynes IFD plug compatible replacement.  Wow, it really works without fuss or muss.  Install completed in an hour or two and everything on my GRT panel works as before. Now I just have to learn how to use it.
Bill "10 years Oct 2021 and 1300 hours" Watson
On 11/18/2021 2:31 PM, Robert Jones wrote:
That would depend on which method you used to do the original weatherstripping. I used the 3/8X7/32 from McMaster Car available here https://www.mcmaster.com/door-seals/water-and-weather-resistant-hollow-foam-rubber-surface-mount-seals/ I left as much door frame material as possible and put this in the channel to be compressed as the door closes. Others used something like this https://www.mcmaster.com/door-seals/oil-resistant-push-on-seals-with-bulb-on-side/.
Robert Jones
On Nov 17, 2021, at 4:53 PM, Jim Combs <jiminlexky(at)gmail.com> (jiminlexky(at)gmail.com) wrote:
--> RV10-List message posted by: Jim Combs <jiminlexky(at)gmail.com> (jiminlexky(at)gmail.com)
Thanks, Jim Combs
