Weird primer leak
PostPosted: Mon Jan 31, 2022 10:00 am    Post subject: Weird primer leak Reply with quote
I have a leak from the back of the primer handle and it's been difficult to figure out. I might just end up replacing the whole thing but was curious if anyone has seen this before.
The top b-nut is tight. I've taken a number of pictures and I can't see any cracks in the fittings or the tube.
https://www.youtube.com/watch?v=TsxCMMe31co
dsavarese0812(at)bellsout
PostPosted: Mon Jan 31, 2022 10:09 am    Post subject: Weird primer leak Reply with quote
Look for cracks in the flare under the tubing sleeve inside the B nut.
Difficult to see unless you physically remove the B nut and inspect the tubing flare.
Dennis
http://forums.matronics.com/viewtopic.php?p=505859#505859
