What did you do with your Europa this week 1/31 - 2/7
Area-51
PostPosted: Sat Feb 05, 2022 9:08 pm    Post subject: What did you do with your Europa this week 1/31 - 2/7 Reply with quote
After pulling out the last of the instrument panel sections to flip the trim switch upside down and finish giving all the aircraft’s electrical terminals a safety assessment the plane and I went for a lazy local flight trying to keep it under 80kt so the 100hp Savannah could keep up; 75kt and feeling a little bit mushy, still no chance for the Savannah... first approach floated a bit too deep for comfort so went around... second approach brought it down at a steady 60kt and 500fpm; rounded out, kept the height steady as the stick came back, attitude felt right, heard the rumble of the main and tail wheels spooling up; greased it on, back tracked, packed up, went home happy.
n7188u
PostPosted: Mon Feb 07, 2022 12:47 pm    Post subject: Re: What did you do with your Europa this week 1/31 - 2/7 Reply with quote
Sounds great. But.... what’s a Savannah?
I did a google search and, assuming it’s an airplane, found something that looks like a Zenith 750 made by a company in Italy. Is that it?
Chris
Area-51
PostPosted: Mon Feb 07, 2022 4:24 pm    Post subject: Re: What did you do with your Europa this week 1/31 - 2/7 Reply with quote
Correct Chris; that’s the one... very rugged and capable STOL performer.. its a challenge to fly together as both aircraft are operating close to opposite ends of the envelope. The europa really needs flaps deployed to allow the savannah to keep up.
n7188u
PostPosted: Mon Feb 07, 2022 4:49 pm    Post subject: Re: What did you do with your Europa this week 1/31 - 2/7 Reply with quote
Cool 👍
