Tyco W31 toggle breaker
dlm34077(at)gmail.com
PostPosted: Sun Mar 27, 2022 12:03 pm    Post subject: Tyco W31 toggle breaker Reply with quote
Anyone have any experience with their reliability, MTBF, failure indications? probability of failure and any relationship to current load?
David
N46007
Bob Turner
PostPosted: Sun Mar 27, 2022 6:48 pm    Post subject: Re: Tyco W31 toggle breaker Reply with quote
I have about 8 of them. One of them suffered infant mortality at about 4 hours since new. Mechanically failed, knocked a hole in the back of the plastic case, when first turned on, I think. Others (plus replacement) are all still working fine, ten years later.
Bob Turner
RV-10 QB
bdgillespie215(at)gmail.c
PostPosted: Mon Mar 28, 2022 5:42 am    Post subject: Tyco W31 toggle breaker Reply with quote
Another data point. I had one semi D.O.A.
No connectivity up front with switch on - unless the screw tab was “wiggled” then it was intermittent. It was replaced under warranty. The replacement has been flawless for over a year now.
Byron
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=506413#506413
carl.froehlich(at)verizon
PostPosted: Mon Mar 28, 2022 9:47 am    Post subject: Tyco W31 toggle breaker Reply with quote
I used them in three RVs over the last ~22 years. Never had a failure.
I use them for things like:
- Boost Pump
- Landing and Nav/Strobes
- Pitot heat
I use the Tyco pull breakers for stuff that is not controlled with a switch, like:
- Avionics
- Alternator voltage regulator
- Trim servos
- Autopilot servos
Carl
David
N46007
