a good landing
Fred Klein
PostPosted: Mon May 23, 2022 3:11 pm    Post subject: a good landing Reply with quote
Gents…
Like all of you, I’m familiar with the phrase, “a good landing is any landing which you can walk away from”.
I’ve just been introduced to a follow on…i.e.,…”a really great landing is one in which you can use the airplane again”.
Having walked away from stuffing my Europa in some trees, I’m now on my way to getting it back in shape so I can use it again…I’ll keep you posted as I proceed.
Fred
A194
peterz(at)zutrasoft.com
PostPosted: Mon May 23, 2022 3:21 pm    Post subject: a good landing Reply with quote
Great to hear that yer getting her (and yourself) back in the game!
Must be heartbreaking though.
All the best,
PeteZ
On May 23, 2022, at 8:17 PM, fklein(at)orcasonline.com wrote:
Gents…
Fred
A194
Fred Klein
PostPosted: Mon May 23, 2022 6:32 pm    Post subject: a good landing Reply with quote
On May 23, 2022, at 5:21 PM, Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
--> Europa-List message posted by: Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)>Great to hear that yer getting her (and yourself) back in the game!
Pete...your empathy is much appreciated...
surprisingly, I’ve yet to experience heartbreak, though I admit to some self-flagellation…thus far, I’ve only found damage which I characterize as superficial, though some suspicions remain…
most of the trees I bumped into were young Alders which swayed and bended quite a bit, so most of the impacts at approx. 50 kts were not harsh…a couple of Shore Pines OTOH were much sturdier and when one snapped off, the sharp end gouged a ragged rip into the fuselage underside which happily, did not rupture any fuel lines.
much gratitude that I didn’t hit a building or vehicle or a couple of pedestrians
thanks to the composite construction vocabulary, everything looks repairable, even my (totally custom) lower cowling…I’m very grateful that my fears of damage to the primary structure, particularly the interfaces between the CM, the engine mounting frame and the airframe were unfounded…am assembling new blades in the hub of my ground-adjustable prop…when complete I’ll have a go at starting the engine…
my back injuries, not resulting from the crash, but totally avoidable if I’d have remained in the cockpit instead of blindly exiting the aircraft and falling 12 feet to the ground...are slowing me down…but healing nonetheless…
Fred
A194
