ronburnett(at)charter.net Guest
Posted: Tue Sep 27, 2022 5:15 am Post subject: Battery maintainers |
It seems the all the new battery minders do not include an adapter for a cigar plug as I have in my soon to be sold RV6A.
Any recommendations?
1. For type of maintainer?
2. To modify my old plug in adapter by stripping wires and putting attachments for the clip on features they all possess?
Thanks to all,
Ron Burnett
Electrically challenged Marine 😁
May you have the Lord's blessings today!
Sent from my iPad
david(at)carter.net Guest
Posted: Tue Sep 27, 2022 6:30 am Post subject: Battery maintainers |
I've had great results with an earlier version of this maintainer. I attached the eyelet adapter to the battery & affixed the other end to the engine mount just inside the oil filler door in my cowling. I leave it plugged in whenever the plane is in the hangar.
https://amazon.com/NOCO-Fully-Automatic-X-Connect-Terminal-Accessory/dp/B0B6TZM9GN
Here's a less expensive, lower-capacity version that should be adequate for most of the batteries in our OBAM planes:
https://amazon.com/NOCO-Fully-Automatic-X-Connect-Terminal-Accessory/dp/B08MG3G9NV
David Carter
david(at)carter.net (david(at)carter.net)
On Tue, Sep 27, 2022 at 9:16 AM Ron Bur <ronburnett(at)charter.net (ronburnett(at)charter.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: Ron Bur <ronburnett(at)charter.net (ronburnett(at)charter.net)>
Thanks to all,
Ron Burnett
Sent from my iPad
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
skywagon185(at)gmail.com Guest
Posted: Fri Sep 30, 2022 8:40 am Post subject: Battery maintainers |
Keep in mind that many of the battery maintainers draw a small amount of current if connected to the battery and NOT plugged into AC. Over time, if permanently attached to the battery, they will draw the battery down.
On Tue, Sep 27, 2022 at 7:33 AM David Carter <david(at)carter.net (david(at)carter.net)> wrote:
Posted: Fri Sep 30, 2022 9:19 am Post subject: Battery maintainers |
The part that is permanently attached is just two wires that go from the battery posts to a connector inside the oil filler door. It's not draining the battery. The maintainer stays in the hangar & is always plugged in to an outlet. It's never connected to the battery unless also plugged in & operating.
On Fri, Sep 30, 2022 at 12:41 PM skywagon185guy <skywagon185(at)gmail.com (skywagon185(at)gmail.com)> wrote:
| Quote: | Keep in mind that many of the battery maintainers draw a small amount of current if connected to the battery and NOT plugged into AC. Over time, if permanently attached to the battery, they will draw the battery down.
David Carter
steve(at)tomasara.com Guest
Posted: Sat Oct 01, 2022 8:24 am Post subject: Battery maintainers |
| Quote: | The part that is permanently attached is just two wires that go from the
operating. |
The point about an "unplugged" maintainer is sometimes more relevant than you expect. We had a brief power outage at my hangar a few months back but the power event was such that *all* of the GFIs in my hangars popped. Unfortunately, I didn't realize this till after all the food in the fridge spoiled and the battery I had on a maintainer was ruined.
Steve Stearns
Boulder/Longmont CO
'46 Taylocraft BC-12D / O235 Longeze
