Posted: Mon Oct 03, 2022 9:50 am Post subject: sealing up the gas tank seat back |
I am coming towards the end of my tank build...the left outlet was too close to the torque tube and had to be redone. And the spacers which stop the tank bulging had to have their top angle removed (didnt fit) and nut plates put on. i still have to fit the filler tube . And then sand to ensure no flakes could block the outlets. And then put the top on. And adjust the hole for the filler tube in yhe rear bulkhead.... No matter. I can feel I'm getting close.
The next step is engine testing before final closing.
Wrt closing, to those that have done this before how does one go about the inside reinforcements? (outside seems straightfoward) Any wisdom to share
thanks
will
William Daniell
+1 786 878 0246
Posted: Tue Oct 04, 2022 5:04 am Post subject: sealing up the gas tank seat back |
just to clarify my question relates to the interior lay ups. is there a trick to this?
William Daniell
+1 786 878 0246
On Mon, Oct 3, 2022, 12:52 William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
| Quote: | I am coming towards the end of my tank build...the left outlet was too close to the torque tube and had to be redone. And the spacers which stop the tank bulging had to have their top angle removed (didnt fit) and nut plates put on. i still have to fit the filler tube . And then sand to ensure no flakes could block the outlets. And then put the top on. And adjust the hole for the filler tube in yhe rear bulkhead.... No matter. I can feel I'm getting close.
thanks
will
William Daniell
+1 786 878 0246
peterz(at)zutrasoft.com Guest
Posted: Tue Oct 04, 2022 5:15 am Post subject: sealing up the gas tank seat back |
Fwiw
On my hummelbird tank, i didn't bother with internal seam layups, just ensured good seam epoxy coverage and a couple external layups. No issues to date. My mating seam mated well, using a simple single layer packing tape release
Posted: Sat Oct 08, 2022 3:27 pm Post subject: sealing up the gas tank seat back |
thanks pete....I guess Im just be anal about it....
William Daniell
LONGPORT
+1 786 878 0246
On Tue, Oct 4, 2022 at 9:17 AM Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
Fwiw
On my hummelbird tank, i didn't bother with internal seam layups, just ensured good seam epoxy coverage and a couple external layups. No issues to date. My mating seam mated well, using a simple single layer packing tape release.
PeteZ
| Quote: | On Oct 4, 2022, at 9:10 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
William Daniell
+1 786 878 0246
thanks
will
William Daniell
+1 786 878 0246
Posted: Sat Oct 08, 2022 3:48 pm Post subject: sealing up the gas tank seat back |
I was more worried about internally not being able to peelply (if i could even figure out the layups through the filler) and ensure there were no marginal edges why may have ended up as loose bits down the road.
PeteZ
| Quote: | On Oct 8, 2022, at 7:33 PM, William Daniell <wdaniell.longport(at)gmail.com> wrote:
William Daniell
LONGPORT
+1 786 878 0246
Fwiw
PeteZ
William Daniell
+1 786 878 0246
thanks
will
William Daniell
+1 786 878 0246
Posted: Sat Oct 08, 2022 4:46 pm Post subject: sealing up the gas tank seat back |
ah yes well there is that too which has me a little concerned...i have been wire brushing and sanding the inside to try to ensure that there are no loose bits.
furthermore this was one of the reasons for keeping the finger filters as opposed to using straight through bulkhead fittings for the outlets
Actually wrt the inside layups i was refering to the inside of the cockpit module ....
will
William Daniell
+1 786 878 0246
On Sat, Oct 8, 2022, 19:50 Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
PeteZ
| Quote: | On Oct 8, 2022, at 7:33 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
William Daniell
LONGPORT
+1 786 878 0246
Fwiw
PeteZ
William Daniell
+1 786 878 0246
thanks
will
William Daniell
+1 786 878 0246
