PTT switch
MikeP
PostPosted: Fri Jan 06, 2023 8:19 am    Post subject: PTT switch Reply with quote
Have conventional stick mounted PTT. P1 side has become intermittent, so am looking for new switch or sourcing info.
thanks
MikeP
Area-51
PostPosted: Fri Jan 06, 2023 6:55 pm    Post subject: Re: PTT switch Reply with quote
Had this issue about 30hrs ago; found connector block from stick to seat bulkhead section was dirty and loose.... then Milspec PTT switch failed all together 5hrs later... replaced with generic switch from electronic store and fresh wire traces in control column.
