Source for fuel resistant hose for tank outlets
paul.the.aviator(at)gmail
PostPosted: Wed Jan 11, 2023 4:25 pm    Post subject: Source for fuel resistant hose for tank outlets Reply with quote
Hello everyone,
I need to replace the rubber hose on the fuel tank outlets. I seem to recall that it was 1" in diameter.
Could someone advise of a good source in the US?
Thanks, Paul
budyerly@msn.com
PostPosted: Wed Jan 11, 2023 6:00 pm    Post subject: Source for fuel resistant hose for tank outlets Reply with quote
Paul,
Any one inch fuel hose will do.  You must go to a hose supplier not an autoparts store.
See if you have a marine hose supplier.  I have used the Red stripe marine hose from Amazon Hose, I have used Parker Hose from a hydraulic supply house here in Tampa.
As far as the one inch hose, the issue is many places only sell in bulk now days.  Amazon had a supplier that sold it in 5 foot sections for under $50.
Marine supply stores often have red and blue stripe hose and may sell you a foot.  (Red is fuel (higher heat) blue is exhaust (still OK for fuel).  Trident fuel hose is very good but costs about $25 a foot last I checked.
Watch that you can bend and stretch the hose, some are wire reinforced and tough as heck.
Continental ContiTech Pacer 1 in. Softwall Bulk Curb Pump Hose is not bad to work getting on the fuel tank bung.
You should have many marine suppliers around where you live.  Milwaukee isn’t it?
Bud Yerly
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Paul McAllister
Sent: Wednesday, January 11, 2023 7:25 PM
Subject: Europa-List: Source for fuel resistant hose for tank outlets
Hello everyone,
Thanks, Paul
