		docclv(at)windstream.net Guest
				 Posted: Tue Jan 17, 2023 3:38 pm    Post subject: Aileron Alignment |
				Igor:  I don't have pictures showing the Aileron hinges but it is quite
 easy and simple to do.  You need to measure the discrepancy in height of
 the Aileron with reference to the top of the wing by laying a long
 straight edge along the top of the wing down over trailing edge of the
 Aileron.  You may need to hold the straight just outboard or inboard
 along the outboard or inboard edge of the Aileron IF the Aileron is
 higher than the straight edge You will see that the the top of the wing
 is flat and not rounded as it comes down to the Aileron.  Hold the
 Aileron parallel to the straight edge and measure the difference in
 height which could be above the straight edge or below the straight
 edge.  This will tell you how much to raise or lower each hinge of the
 Aileron.  Make note of this.
    Remove the Aileron and Rivet a 3/16" STEEL fender washer (small hole
 same diameter as the #10 bolts and a big outside diameter) to the OUT
 SIDE of each hinge arm using 2 #3 rivets with the 3/16" washer center
 hole moved either up or down from the original hinge holes the amount
 each end of the Aileron was above or below the wing surface as noted above.
    The hinge arms are made of STEEL not ALUMINUM.  Don't use a piece of
 ALUMINUM.  Its hole will wear out with time.
    Then using the washer hole as a guide drill through each hinge arm.
 You will now have the Aileron moved up or down in the hinge arms to make
 the Aileron top surface match the top surface of the wing.  This is
 proper Aileron alignment to assure minimal drag and avoid a "Heavy Wing"
    Reinstall the Aileron using the original 3/16" bolts (hinge pins) and
 check the other clearances and measurements I noted in my "Wing Mounting
 and Rigging" and Vans instructions.  You will have a nice flying FAST
 airplane.
    Note:  You will have to clamp the washers to the hinge arms SECURELY
 so they can't possible move when you drill the rivet holes to rivet the
 washers on the hinge arms.  I would recommend a couple of small Vise
 Grip pliers and an extra hand or Vise to hold things. Good Luck Doc
 N123CV and N784DC
		supik
				 Posted: Tue Jan 24, 2023 1:04 pm    Post subject: Re: Aileron Alignment |
				Thank you Doc, I'll have a look on that.. anyway, pls post pics when you'll be at your airplane.
  _________________ Igor
RV10 in progress |
