werner schneider
Posted: Thu Feb 02, 2023 6:00 am Post subject: iflyrv10 door pins question |
As I had a longer stop due to life, I'm coming back now to one or two things were I just miss informations.
I bought 12 years ago the iflyrv10 door pins and striker plates, the pins had not yet the magnetos in there so I will try to add them myself, the question is about the thread on the pins, anybody any idea what size these are? I've tried several nuts I have but none did work. If someone could post as well a picture of theirs with a measure tape along I would appreciate it seems mine have a longer thread part (1").
I neither can find any instructions for them
Thanks for your help, not so easy to find all the items again I left 10 years ago
Cheers Werner
rleffler
Posted: Thu Feb 02, 2023 6:32 am Post subject: iflyrv10 door pins question |
I recently learned something the hard way. If you have FlyRV10 pins and Aerosport interior panels, there isn’t enough clearance to use the vans supplied magnetic switches.
The magnet in the ifyrv10 pin only works head on with the switch. Whereas, the planearound pin magnets can work perpendicular to the pins, which solves the issue with the clearance with the Aerosport interior panel.
If you've not installed them yet, I would highly recommend the planearound door pins and center latch over the iflyrv10 pins. I know it's extra money, but it's worth it.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of werner schneider <glastar(at)gmx.net>
Sent: Thursday, February 2, 2023 9:00:27 AM
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Subject: iflyrv10 door pins question
--> RV10-List message posted by: "werner schneider" <glastar(at)gmx.net>
Cheers Werner
http://forums.matronics.com/viewtopic.php?p=510099#510099
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; - List Contribution Web Site -
p; -Matt Dralle, List Admin.
ps://matronics.com/contribution
_________________ Bob Leffler
N410BL - Phase I
partner14
Posted: Thu Feb 02, 2023 7:13 am Post subject: iflyrv10 door pins question |
Simply put, if you follow Bob's advice below, you wll NEVER need any kind of sensor to tell you the door is closed. The latch in the MIDDLE of the door solved ALL the problems.
On Thursday, February 2, 2023 at 08:42:03 AM CST, Bob Leffler <bob(at)thelefflers.com> wrote:
Get Outlook for iOS
Cheers Werner
Email Forum -
ums.matronics.com
matronics.com
40636 |
werner schneider
Posted: Thu Feb 02, 2023 7:39 am Post subject: iflyrv10 door pins question |
Thanks Bob,
I have the planearound center latch already, as I need to fit the magnets anyway I would use the Vans magnetos and that works (just tried it out).
So back to my question any idea about the thread size
On 02.02.2023 15:32, Bob Leffler wrote:
Quote: | I recently learned something the hard way.   If you have FlyRV10 pins and Aerosport interior panels, there isn’t enough clearance to use the vans supplied magnetic switches.
The magnet in the ifyrv10 pin only works head on with the switch. Â Whereas, the planearound pin magnets can work perpendicular to the pins, which solves the issue with the clearance with the Aerosport interior panel.
If you've not installed them yet, I would highly recommend the planearound door pins and center latch over the iflyrv10 pins. Â I know it's extra money, but it's worth it.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com> (owner-rv10-list-server(at)matronics.com) on behalf of werner schneider <glastar(at)gmx.net> (glastar(at)gmx.net)
To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) <rv10-list(at)matronics.com> (rv10-list(at)matronics.com)
Subject: iflyrv10 door pins question Â
--> RV10-List message posted by: "werner schneider" <glastar(at)gmx.net> (glastar(at)gmx.net)
Cheers Werner
Email Forum -
p;Â Â - MATRONICS WEB FORUMS -
ums.matronics.com
p;Â - NEW MATRONICS LIST WIKI -
matronics.com
p;Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â -Matt Dralle, List Admin.
Vol88
Posted: Thu Feb 02, 2023 1:25 pm Post subject: Re: iflyrv10 door pins question |
Werner,
I believe the threads you are asking about are specified in Step 1 on page 45-14 - 5/16" x 24 threads per inch.
Tom
werner schneider
Posted: Thu Feb 02, 2023 2:28 pm Post subject: iflyrv10 door pins question |
Thanks Tom,
it seems the x24 is correct, it's just strange as I can not screw an AN5
nut onto the pins, maybe it is by design as they then hold better inside
the alu tube?
Cheers Werner
Vol88
Posted: Thu Feb 02, 2023 3:05 pm Post subject: Re: iflyrv10 door pins question |
I just tried an AN5 nut on the stud that connects my aluminum tube to my Planearound pin. It fit perfectly, with no drag.
Perhaps your threads were damaged or contaminated? You could try running a rethreader (thread cleaner) to check and straighten the threads. I would start with a thread gauge to make sure it's 5/16-24 first.
Tim Olson
Posted: Thu Feb 02, 2023 3:59 pm Post subject: iflyrv10 door pins question |
If that doesn't work, I'm guessing it's 5/16-18 if it looks coarse.
I can't remember for sure.
http://forums.matronics.com/viewtopic.php?p=510113#510113
werner schneider
werner schneider
Posted: Fri Feb 03, 2023 5:39 am Post subject: iflyrv10 door pins question |
Thanks Tim, I have to see where I misplaced my imperial thread guide
> first.
