Jim Kelly
Posted: Wed Feb 15, 2023 1:52 am Post subject: Europa-List Digest: 13 Msgs - 02/14/23 |
Dear All, regrettably I experienced a ground loop in my Classic taildragger. The undercarriage and prop were damaged. Can anyone help with the replacement of the Airmaster prop. Thanks Jim Kelly G-BWEG.
On Wed, 15 Feb 2023, 07:33 Europa-List Digest Server, <europa-list(at)matronics.com (europa-list(at)matronics.com)> wrote:
| Quote: | *
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2023-02-14&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2023-02-14&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Tue 02/14/23: 13
Today's Message Index:
1. 03:05 AM - Re: No charge lamp stays on (GTH)
2. 04:39 AM - Re: New engine runs a little rough when weather is cold. (Area-51)
3. 08:28 AM - Re: No charge lamp stays on (Martin Tuck)
4. 09:45 AM - Re: No charge lamp stays on (Paul Mansfield)
5. 10:46 AM - Re: New engine runs a little rough when weather is cold. (dmac7)
6. 11:37 AM - Re: No charge lamp stays on (William Daniell)
7. 11:40 AM - Re: MT04 Engine mounts (William Daniell)
8. 11:48 AM - Re: No charge lamp stays on (GTH)
9. 12:40 PM - Re: No charge lamp stays on (MIKE CHRISTINE DUANE)
10. 06:44 PM - Re: New engine runs a little rough when weather is cold. (n7188u)
11. 06:58 PM - Re: No charge lamp stays on (Martin Tuck)
12. 07:09 PM - Anyone need a McMaster Carr Catalog? (rparigoris)
13. 07:48 PM - Re: New engine runs a little rough when weather is cold. (Area-51)
________________________________ Message 1 _____________________________________
Time: 03:05:35 AM PST US
Subject: Re: No charge lamp stays on
From: GTH <gilles.thesee(at)free.fr (gilles.thesee(at)free.fr)>
Le 14/02/2023 03:26, Martin Tuck a crit:
> Hi Folks,
> Started my 912UL today (first time for 2-3 months) and it started
> first time! However, I noticed that the 12V 'no-charge' lamp
> (connected to the rectifier pins L and C) remained illuminated
> indicating no charge.
> I ran the engine a while to get it up to temp but the lamp stayed on
> and after shut down my battery voltage had dropped below 11.5V. so it
> is definitely is not being charged.
> I'm sure it could be a number of things from a dodgy rectifier to
> issues with the alternator.
> Any pointers as to what to look first at would be appreciated. /
Hi Martin,
I'd first check actual voltages with a reliable voltmeter, then perform
a serious check of the wiring and connections.
Did your alternator charge before? Did you disconnect/connect /anything
/since last time you ran the engine with no issues?
Best regards
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
________________________________ Message 2 _____________________________________
Time: 04:39:30 AM PST US
Subject: Re: New engine runs a little rough when weather is cold.
From: "Area-51" <goldsteinindustrial(at)gmail.com (goldsteinindustrial(at)gmail.com)>
Checking O2 levels without drilling holes in exhaust systems; see pics... That's
how its done.
Strap the tail wheel securely to a pole or pickup truck's tow hitch and run WOT
at engine operating temps.
I've had my 80hp idle smooth at 600rpm while setting idle mixtures and balancing
carbis.. the 100hp will probably tick over nicely at 1000rpm without a fuss
during tuning... Anything below 500rpm on either spec engine will see the ignition
modules shut down.
Once tuning is set it won't have any reason to alter; check it at each 100hr or
annual if desired.
http://forums.matronics.com/viewtopic.php?p=510165#510165
http://forums.matronics.com//files/362f0bc8_cbf0_4542_bf20_f6de7b680f81_791.jpeg
http://forums.matronics.com//files/53b2aae1_e9b1_4447_af53_70ce230454b6_106.jpeg
http://forums.matronics.com//files/644bf1fd_eb3d_4263_b24c_33fbc62a9ce3_178.jpeg
________________________________ Message 3 _____________________________________
Time: 08:28:25 AM PST US
From: Martin Tuck <mjktuck(at)cs.com (mjktuck(at)cs.com)>
--- MIME Errors - No Plain-Text Section Found ---
A message with no text/plain MIME section was received.
The entire body of the message was removed. Please
resend the email using Plain Text formatting.
HOTMAIL is notorious for only including an HTML section
in their client's default configuration. If you're using
HOTMAIL, please see your email application's settings
and switch to a default mail option that uses "Plain Text".
--- MIME Errors No Plain-Text Section Found ---
________________________________ Message 4 _____________________________________
Time: 09:45:01 AM PST US
From: Paul Mansfield <europaul383(at)hotmail.com (europaul383(at)hotmail.com)>
Subject: RE: No charge lamp stays on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________________________________ Message 5 _____________________________________
Time: 10:46:00 AM PST US
From: "dmac7" <dmac7(at)outlook.com (dmac7(at)outlook.com)>
Hello Chris, that was a interesting video you shared, years ago I drag raced a
mildly modified '70 Ford Mustang 351C engine, I didn't have a oxygen sensor I
used the time and speed to tell me how to jet the carb (mostly the speed).
I was running Shell V'Power and I tried 100LL avgas which slowed me down actually,
puzzled I tested the specific gravity of both fuel types...big difference.
100LL is always .72 but auto fuel changes greatly seasonally. The summer Shell
VPower was .82 giving much richer mixture, in winter I tested Shell VPower
and it was .75.
The lesson is, if winter fuel has a lighter specific gravity it will give you a
leaner mixture than what you had in summer. Fuel density matters too
http://forums.matronics.com/viewtopic.php?p=510168#510168
________________________________ Message 6 _____________________________________
Time: 11:37:17 AM PST US
From: William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)>
I had the same issue - Bob Nickolls said that the charge light system in
the Ducati regulator is very primitive and not to pay attention. A
reliable voltmeter is required.
Eventually my charge light went out by itself. The battery charged just
fine while it was on.
William Daniell
LONGPORT
+1 786 878 0246
On Tue, Feb 14, 2023 at 12:46 PM Paul Mansfield <europaul383(at)hotmail.com (europaul383(at)hotmail.com)>
wrote:
> Which video Martin (link or vid ref number)?
> I thought I'd watched them all, but don't recall one on Reg/Rec or
> charging troubleshooting...!
> Cheers,
> Paul M
> G-PLPM
> -------- Original message --------
> Date: 14/02/2023 16:30 (GMT+00:00)
> To: europa-list(at)matronics.com (europa-list(at)matronics.com)
> Thanks Giles,
> I haven=99t done anything to the aircraft since the last time I fle
w and all
> seemed well then. I found a good video on troubleshooting the system on t
he
> Rotax Owners site so I=99ll be looking to perform those checks and
see what
> might be going on.
> Martin
> Sent from my iPhone
> On Feb 14, 2023, at 5:07 AM, GTH <gilles.thesee(at)free.fr (gilles.thesee(at)free.fr)> wrote:
> =EF=BB
> Le 14/02/2023 ?? 03:26, Martin Tuck a ??crit??:
> <MJKTuck(at)cs.com (MJKTuck(at)cs.com)> Hi Folks, <Charge lamp issue>*
> Hi Martin,
> I'd first check actual voltages with a reliable voltmeter, then perform a
> Did your alternator charge before? Did you disconnect/connect *anything *
> Best regards
> Gilles
> <https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fcont
rails.free.fr%2F&data=05%7C01%7C%7C8ea3591876ba4f2447af08db0ea8cabc%7C84d
f9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638119890335969623%7CUnknown%7CTWFp
bGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%
7C3000%7C%7C%7C&sdata=InRipetsCPzljMdA%2BeJ5Dd3R1KF31dtQ5pgJCi%2FQwZA%3D&
reserved=0>
> <https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Flapi
erre.skunkworks.free.fr%2F&data=05%7C01%7C%7C8ea3591876ba4f2447af08db0ea8
cabc%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638119890335969623%7CUnkn
own%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV
CI6Mn0%3D%7C3000%7C%7C%7C&sdata=lk5LfCbl%2BC26gt8XwYaPdiWErbqpymRoYEX1Uvh
Jhhs%3D&reserved=0>
________________________________ Message 7 _____________________________________
Time: 11:40:30 AM PST US
Subject: Re: MT04 Engine mounts
Pete
How much did you shorten the spacers?
Will
William Daniell
LONGPORT
+1 786 878 0246
On Sat, Feb 11, 2023 at 5:57 PM Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
> I love my lords.waaaay quieter than the old europa rubbers,
> Cheers,
> PeteZ
> On Feb 11, 2023, at 5:08 PM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
> =EF=BB
> Re the motor mounts:
> Engine Rubber Isolation Mounts:
> 1. Europa Rotax Mount MT04 hard mount.
> Alternate isolation mount:
> 1. A/C Spruce Part# 08-00662 but not sure of how firm the
> rubber is.
> MFR Model # SET OF 8 About $50 plus shipping/tax
> 2. Lockwood 860-690 is really expensive $30 each. Just a Lord
> Mount J3608-1
> Bud Yerly
> *From:* owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <
> owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> *On Behalf Of *Paul McAllister
> *Sent:* Saturday, February 11, 2023 3:59 PM
> *To:* europa-list(at)matronics.com (europa-list(at)matronics.com)
> *Subject:* MT04 Engine mounts
> Hi, is anyone aware of a US supplier for the MT04 engine mounts or is
> Europa the only source. - Paul
________________________________ Message 8 _____________________________________
Time: 11:48:17 AM PST US
Le 14/02/2023 20:36, William Daniell a crit:
> in theDucati regulatoris veryprimitive and not to pay attention.
> A reliable voltmeter is required.
> Eventuallymy charge light went out by itself. Thebattery charged
> just fine while it was on.
William and all,
Agreed.
First measure actual voltages.
Yes Bob Nuckolls on http://www.aeroelectric.com/ and on the 'List is key.
Best regards
Gilles
________________________________ Message 9 _____________________________________
Time: 12:40:24 PM PST US
From: MIKE CHRISTINE DUANE <duanefamly(at)aol.com (duanefamly(at)aol.com)>
I would imagine you can tell if it=99s operating properly if your pane
l voltage reading prior to start is about 12.5volts and with engine running (
charging system working properly) you should see about 14.8volts.
Mike Duane N377EA
Europa XS Conventional Gear
> On Feb 14, 2023, at 12:48 PM, GTH <gilles.thesee(at)free.fr (gilles.thesee(at)free.fr)> wrote:
> =EF=BB
> Le 14/02/2023 ?? 20:36, William Daniell a ??crit??:
>> I had the same issue - Bob Nickolls said that the charge light system in t
he??Ducati regulator??is very??primitive and not to pay attention.?? ??A rel
iable voltmeter is required.??
>> Eventually??my charge light went out by itself.?? The??battery charged ju
> William and all,
> Agreed.
> Best regards
> Gilles
________________________________ Message 10 ____________________________________
Time: 06:44:39 PM PST US
From: "n7188u" <chmgarb(at)gmail.com (chmgarb(at)gmail.com)>
All very good info. Thanks. A couple of comments:
- I have balanced carbs at 3500 and agree found it to work well. But there is so
much info out there. Some say better at lower RPM, some at higher. And since
Rotax doesn't say, well, here we are. I tried at the lower range this time.
- I saw your O2 setup a while back Area-51. And I like it. But heard that having
the sensor too close to the pipe exit can cause outside air to mix with the
exhaust and produce erroneous readings. But your solution is certainly attractive.
Who sells that short adapter to mount the O2 sensor and coupling hoses?
- The info from dmac7 is very interesting. These issues I am having started this
winter (well, if you can call it that in Florida). But we do get winter fuel
here too. Per Lockwood, he says winter fuels are terrible for our use. Maybe
that is the culprit and the solution is to retune carbs during winter. I have
to do the same on my 503 powered Kolb (24 years old now) but since that is second
nature and expected in the 2-stroker I never had issues.
I will fly with this new tuning setup and will report back at some time in the
future.
Chris
http://forums.matronics.com/viewtopic.php?p=510174#510174
________________________________ Message 11 ____________________________________
Time: 06:58:48 PM PST US
From: Martin Tuck <MJKTuck(at)cs.com (MJKTuck(at)cs.com)>
Hi Paul,
Assuming you are a subscriber to RotaxOwner.com, the video can be found
under Videos: 912 Videos: Charging System Troubleshooting.
https://www.rotax-owner.com/en/videos-topmenu/rotax-minute/404-charging
Martin Tuck
> Cheers,
> Paul M
> G-PLPM
> Thanks Giles,
> I havent done anything to the aircraft since the last time I flew and
> all seemed well then. I found a good video on troubleshooting the
> system on the Rotax Owners site so Ill be looking to perform those
> checks and see what might be going on.
> Martin
> Sent from my iPhone
>>> Hi Folks,
>>> <Charge lamp issue>/
>> Hi Martin,
>> perform a serious check of the wiring and connections.
>> /anything / since last time you ran the engine with no issues?
>> Best regards
>> Gilles
________________________________ Message 12 ____________________________________
Time: 07:09:14 PM PST US
Subject: Anyone need a McMaster Carr Catalog?
From: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>
Hi Group
Anyone need a McMaster Carr Catalog? I have a few spares.
Ron P.
http://forums.matronics.com/viewtopic.php?p=510176#510176
________________________________ Message 13 ____________________________________
Time: 07:48:00 PM PST US
Chris, the setup i just bought the bits off fleabay and made one; the case is 3D
printed in PETG with two velcro securing straps and the T'piece for the sensor
i had to custom drill and tap to suit... i can make more units ready to use
out of the box, and they would be around $600 Aud plus postage; the unit can
be used in the cockpit during flight testing for specific altitudes tests also
and has self contained battery power or plug into 12v supply and recharging.
The tail pipe fitting length negates proximity contamination to external atmospheric
air and fits 36mm - 40mm tail pipe sizes with provision for safety cable
attachment should the T'piece depart during flight.
Balancing carbis at 3500/4000 etc is fine however its a lazy way of going about
it and will only offer Intermediate range tuning, so that would be needle height
adjustment only. Adjusting mixtures and butterflies for smooth idle are best
achieved at the lowest possible rpm (operational idle rpm is set afterward);
have had triple SU Aston Martin DB3's happily idling at 150rpm while setting
mixtures... SU and Stromberg CV tuning method would be the most appropriate applied
approach for Bing64 series. The only other point to note is symmetry of
needle height position; if they are not the same height on each carbi and your
tuning is complete then you have an issue remaining either an air leak, high
or low float level, or unbalanced butterfly valves; take everything back to default
and start again to find the reason for rich or lean side.
Seasonal changes in specific gravity of fuels will alter the tuning slightly on
cold startups as it affects the barometric vaporisation point of the fuel (for
Darwinian safety reasons modern pump gas is designed not to vaporise, its designed
to be sprayed and atomised at high pressure). Avgas however will readily
vaporise and has a specific barometric vaporisation point that must be deliverable
and adhered to to prevent vapor locking up to a specified pressure and
temperature.
Bud might offer a better explanation as i never cease to expect everybody to just
automatically know all this stuff!
http://forums.matronics.com/viewtopic.php?p=510177#510177
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
_________________ Jim GBWEG |
peterz(at)zutrasoft.com Guest
Posted: Wed Feb 15, 2023 2:16 am Post subject: Europa-List Digest: 13 Msgs - 02/14/23 |
Sorry to hear.
Don t forget to check the frame’s gear pivot tube for straightness.
PeteZ
| Quote: | On Feb 15, 2023, at 4:59 AM, James Kelly <europajimkelly(at)gmail.com> wrote:
| Quote: | *
HTML Version:
Text Version:
> Hi Folks,
Hi Martin,
Best regards
Gilles
how its done.
modules shut down.
annual if desired.
and it was .75.
William Daniell
LONGPORT
+1 786 878 0246
> Cheers,
> Paul M
> G-PLPM
> Thanks Giles,
w and all
he
see what
> might be going on.
> Martin
> Sent from my iPhone
> =EF=BB
> Hi Martin,
> Best regards
> Gilles
reserved=0>
Jhhs%3D&reserved=0>
Pete
Will
William Daniell
LONGPORT
+1 786 878 0246
> Cheers,
> PeteZ
> =EF=BB
> rubber is.
> Mount J3608-1
> Bud Yerly
William and all,
Agreed.
Best regards
Gilles
Mike Duane N377EA
> =EF=BB
> William and all,
> Agreed.
> Best regards
> Gilles
future.
Chris
Hi Paul,
Martin Tuck
> Cheers,
> Paul M
> G-PLPM
> Thanks Giles,
> Martin
> Sent from my iPhone
>>> Hi Folks,
>> Hi Martin,
>> Best regards
>> Gilles
Hi Group
Ron P.
temperature.
dpark748(at)me.com Guest
Posted: Wed Feb 15, 2023 2:47 am Post subject: Europa-List Digest: 13 Msgs - 02/14/23 |
Dirk Oyen in Belgium is Airmaster chap.Ask his advice?
Dave Park
| Quote: | On 15 Feb 2023, at 09:55, James Kelly <europajimkelly(at)gmail.com> wrote:
| Quote: | *
HTML Version:
Text Version:
> Hi Folks,
Hi Martin,
Best regards
Gilles
how its done.
modules shut down.
annual if desired.
and it was .75.
William Daniell
LONGPORT
+1 786 878 0246
> Cheers,
> Paul M
> G-PLPM
> Thanks Giles,
w and all
he
see what
> might be going on.
> Martin
> Sent from my iPhone
> =EF=BB
> Hi Martin,
> Best regards
> Gilles
reserved=0>
Jhhs%3D&reserved=0>
Pete
Will
William Daniell
LONGPORT
+1 786 878 0246
> Cheers,
> PeteZ
> =EF=BB
> rubber is.
> Mount J3608-1
> Bud Yerly
William and all,
Agreed.
Best regards
Gilles
Mike Duane N377EA
> =EF=BB
> William and all,
> Agreed.
> Best regards
> Gilles
future.
Chris
Hi Paul,
Martin Tuck
> Cheers,
> Paul M
> G-PLPM
> Thanks Giles,
> Martin
> Sent from my iPhone
>>> Hi Folks,
>> Hi Martin,
>> Best regards
>> Gilles
Hi Group
Ron P.
temperature.
Monoman
Posted: Wed Feb 15, 2023 4:10 am Post subject: Europa-List Digest: 13 Msgs - 02/14/23 |
Hello JimYour best bet is to contact Dirk Oyen, he’s the Airmaster rep for Europe.
He is very approachable and helpful.
I did the same and I would be very surprised if the hub internals were not damaged. The hub should also be crack tested.
I can give you his number if required.
Cheers
G-DURO
| Quote: | *
HTML Version:
Text Version:
> Hi Folks,
Hi Martin,
Best regards
Gilles
how its done.
modules shut down.
annual if desired.
and it was .75.
William Daniell
LONGPORT
+1 786 878 0246
> Cheers,
> Paul M
> G-PLPM
> Thanks Giles,
w and all
he
see what
> might be going on.
> Martin
> Sent from my iPhone
> =EF=BB
> Hi Martin,
> Best regards
> Gilles
reserved=0>
Jhhs%3D&reserved=0>
Pete
Will
William Daniell
LONGPORT
+1 786 878 0246
> Cheers,
> PeteZ
> =EF=BB
> rubber is.
> Mount J3608-1
> Bud Yerly
William and all,
Agreed.
Best regards
Gilles
Mike Duane N377EA
> =EF=BB
> William and all,
> Agreed.
> Best regards
> Gilles
future.
Chris
Hi Paul,
Martin Tuck
> Cheers,
> Paul M
> G-PLPM
> Thanks Giles,
> Martin
> Sent from my iPhone
>>> Hi Folks,
>> Hi Martin,
>> Best regards
>> Gilles
Hi Group
Ron P.
temperature.
