		JonathanMilbank
  Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
		Area-51
				 Posted: Sat Apr 01, 2023 10:42 pm    Post subject: Re: Canopy ball stud |
				Most gas struts will have a C strap clip at each end (some have a wire spring clip); extend the strut all the way and remove the clip; the socket will come away from the ball.
 Give the shaft a light coating of silicone grease to affect smooth op.
		rparigoris
				 Posted: Sun Apr 02, 2023 5:19 pm    Post subject: Re: Canopy ball stud |
				Hi Jonathan
 Ends up I have a spare ball stud and just measured it for you.
 A little difficult, I measured across threads and got .186". A 10-32 die wouldn't go on by hand.I tried a 5 x .8mm tap into the nut and it wouldn't go in?
 OK got it figured. The threads are 10-32. They plated after they ran a die on them. I ran die on threads and just a tad of plating came off.
 So:
 ** The threads are 10-32
 ** The length of threaded portion is .390" with a rounded tip
 ** There is a shoulder on the .390" which is .194" diameter and ~.062" long which isn't threaded
 ** Where you grab with a wrench (circle with 2 flats) has the circle diameter at .312" and the flats .270" (7 mm)
 ** The ball is .314" in diameter
 Hope that helps
 Ron P.
