Modification on the fairing Wheels
Olivier.hequet@neuf.fr
PostPosted: Tue May 30, 2023 3:38 am    Post subject: Modification on the fairing Wheels Reply with quote
Hello
How do you inflate your tires on your europa? Do you have a solution to avoid to remove the wheel fairings ? I want to make a little hole but it seems it will be difficult to screw or unscrew the valve cap.
Many thanks for your tips or pictures.
Olivier
F-PAKV 564
Burrilla
PostPosted: Tue May 30, 2023 4:13 am    Post subject: Modification on the fairing Wheels Reply with quote
I have 5-6cm square hinged flaps cut into the sides of the fairings, secured with a single screw into a captive nut.
There is just enough room to get you fingers through the hole after you rotate the wheel so the valve lines up.
If you have the valve caps which have the six sided flats then you can use a small socket to undo/do up but not too tight.
I then have an extension tube which I screw on to the valve to allow me to connect a standard hand pump of electric pump to inflate.
I tend to carry a bicycle pump, which is lightweight, in the aircraft for topping up on trips when needed.
Alan
On 30 May 2023, at 12:38, Olivier.hequet(at)neuf.fr wrote:
Hello
Olivier
F-PAKV 564
http://forums.matronics.com/viewtopic.php?p=510876#510876
PostPosted: Tue May 30, 2023 7:14 am    Post subject: Re: Modification on the fairing Wheels Reply with quote
Thank you Alan for this precision.
