Rotax Airbox temp to dynon
wdaniell.longport(at)gmai
PostPosted: Fri Jul 07, 2023 6:02 am    Post subject: Rotax Airbox temp to dynon Reply with quote
As many of you already know I have turbo-ed 912.
There are many of these in Colombia and nobody has airbox temp sensor and consequently nobody worries about it!
The recent 914-dyno conversation has sparked my interest.  Does anyone have an airbox temp sensor connected to a dynon?
thanks
William Daniell
LONGPORT
+1 786 878 0246
rparigoris
PostPosted: Fri Jul 07, 2023 2:37 pm    Post subject: Re: Rotax Airbox temp to dynon Reply with quote
Hi Willaim
We have an Ilec Variometer that has a temperature readout. We have a rotary switch that can select 6 different inputs including ambient, airbox and inside instrument module. I made a probe that goes into the airbox:
https://1drv.ms/f/s!Ah1S270Nwg9V5URcu_c2hgZI7iv7?e=ahYUuU
I imagine if Dynon or someone else doesn't offer an off the shelf probe, you can roll your own.
Ron P.
erichdtrombley(at)juno.co
PostPosted: Sat Jul 08, 2023 5:48 am    Post subject: Rotax Airbox temp to dynon Reply with quote
Hi Will,
I monitor airbox temperature with my Dynon Skyview using one of the general purpose inputs.
Erich Trombley
N28ET Classic Mono 914
PostPosted: Sat Jul 08, 2023 10:24 am    Post subject: Rotax Airbox temp to dynon Reply with quote
Thanks erich
What sensor do you use?
Will
William Daniell
+1 786 878 0246
On Sat, Jul 8, 2023, 09:51 Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)> wrote:
--> Europa-List message posted by: Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)>
Hi Will,
Erich Trombley
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
PostPosted: Sun Jul 09, 2023 12:28 pm    Post subject: Rotax Airbox temp to dynon Reply with quote
Hi Will,
I am using an EGT bayonet probe I had as a spare. The airbox fitting is the same as that on the welded boss on the exhaust tubes.
Erich Trombley
N28ET Classis Mono 914
