unknow part need help
werner schneider
PostPosted: Wed Oct 25, 2023 12:54 pm    Post subject: unknow part need help Reply with quote
Hi there,
I found this part and first thought it might be the F1011 bracket for the cables, but meanwhile I doubt, the nomination would tell it is in the fuselage kit included, but referenced it is only in the cabling instructions.
[img]cid:part1.7kLuL25y.qNY2M0Jo(at)gmx.net[/img]
appreciate your help!
Cheers Werner
 Filesize:  2.48 MB
 Viewed:  11665 Time(s)
Vol88
PostPosted: Thu Oct 26, 2023 7:24 am    Post subject: unknow part need help Reply with quote
Werner, the cabling bracket called out in OP-37 is F-10111 (L or R) and it is only long enough for two left brackets and two right brackets.
Unfortunately, I don’t know what part you have pictured.
Tom
From: <owner-rv10-list-server(at)matronics.com> on behalf of Werner Schneider <glastar(at)gmx.net>
Reply-To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Wednesday, October 25, 2023 at 16:12
To: rv10-list <rv10-list(at)matronics.com>
Subject: RV10-List: unknow part need help
Hi there,
Cheers Werner
