RG-316 v RG-400
rv8iator
PostPosted: Wed Dec 13, 2023 9:13 am    Post subject: RG-316 v RG-400 Reply with quote
Looking at the specs for antenna coax the RG-316 v RG-400, the RG-316 performs as well as RG-400 for the short runs and RF frequencies used in our OBAM aircraft.  The RG-316 is 1/4 the weight/ft as RG-400. Mechnicaly the RG-316 uses the same insulation materials and same braided shield as the RG-400.
Is there something I am missing as to why I wouldn't use RG-316?
Chris Stone
Another RV
C. Stone (RV8iator)
Ceengland
PostPosted: Wed Dec 13, 2023 9:49 am    Post subject: RG-316 v RG-400 Reply with quote
Assuming the same RF specs (including power handling, if talking about transponder use; did you check that?), the biggest issue might be emergency access to connectors & tools to repair it. The tiny diameter would certainly make running it easier in certain situations.
Charlie
On Wed, Dec 13, 2023 at 11:16 AM Christopher Cee Stone <rv8iator(at)gmail.com (rv8iator(at)gmail.com)> wrote:
Chris Stone
Another RV
Charlie
rv8iator
PostPosted: Wed Dec 13, 2023 10:29 am    Post subject: RG-316 v RG-400 Reply with quote
RG-316: Max power at 1.05 GHz is 125 Watts (I am using RG-400 for Xponder).  ~350 Watts max power at comm frequencies. Attenuation at 0.15 Ghz (nominally comm freq)  0.096 db/ft (RG-400 (at) .30 Ghz is 0.073 db/ft) RG-400 doesn't list attenuation below 300 Mhz).  Nominal capacitance is almost identical, 97 v. 94 pf/m.
Spec wise it looks good.  Long runs to wingtip antennas save about 4 lb over RG-400.
On Wed, Dec 13, 2023 at 9:51 AM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Charlie
Chris Stone
Another RV
C. Stone (RV8iator)
matronics(at)rtist.nl
PostPosted: Wed Dec 13, 2023 10:43 am    Post subject: RG-316 v RG-400 Reply with quote
You may want to double-check those weight claims. I've read 5 sheets for RG-316 and they all claim some other weight.
Charlie
Chris Stone
Another RV
Voyager
PostPosted: Wed Dec 13, 2023 10:58 am    Post subject: RG-316 v RG-400 Reply with quote
The biggest issues with copper clad steel conductor rather than all copper is susceptibility to corrosion if the exposed to moisture and attenuation at DC for applications like satellite where power is transferred through the cable in addition to signal. Also, CCS cable is tough on cutting tools so don’t you your finest cutters to cut the cable.
RG-316 is probably fine for use in most airplane applications, though I wouldn’t use it for GPS antennas given their low signal levels and need to minimize attenuation. RG-316 has substantially higher attenuation than RG-400.
If you install outdoor style weather proof connectors, you can probably keep moisture away from the cut end of the steel conductor and avoid corrosion issues a decade or so down the road.
You must be running several runs to the wingtips to save 4 lbs. I show 60’ of RG400 to weigh about 3 lbs (using 50 lbs /1,000’) and 60’ of RG316 to weight about 0.7 lbs for a weigh saving of 2.3 lbs for two runs to the wingtips. It would take more than 100’ of coax to yield a 4lb weight saving.
Makes me glad that my antennas are all fuselage mounted with short cable runs where RG400 isn’t a problem either for weight or bend radius.
Matt
Sent from my iPad
On Dec 13, 2023, at 1:31 PM, Christopher Cee Stone <rv8iator(at)gmail.com> wrote:
Charlie
Chris Stone
Another RV
rv8iator
PostPosted: Wed Dec 13, 2023 11:06 am    Post subject: RG-316 v RG-400 Reply with quote
Huber+Suhner(Mouser) lists weights asRG-400 6.4 kg/100m
RG-316 1.6 kg/100m
RG-400 is 4x the weight of RG-316
I would hope that the weight of cable is consistent between manufacturers.
...chris
On Wed, Dec 13, 2023 at 10:46 AM Rob Turk <matronics(at)rtist.nl (matronics(at)rtist.nl)> wrote:
Charlie
Chris Stone
Another RV
C. Stone (RV8iator)
PostPosted: Wed Dec 13, 2023 12:15 pm    Post subject: RG-316 v RG-400 Reply with quote
You are right, it's indeed 1/4th the weight. I guess I looked at the
wrong sheets.
The attenuation is quite a bit different though. You lose half of your
signal for every 3dB.
I'm looking at Allied Wire & Cable:
https://www.awcwire.com/rg-catalog/rg316-coax-cable
https://www.awcwire.com/rg-catalog/rg400-coax-cable
The PDFs list the attenuation at 100MHz to be 4.5 - 4.5dB /100ft for
RG400 and 7.8-11.0 dB/100ft for RG316. Comm is 118-136MHz so a bit more
attenuation for both types. With short runs this may be acceptable.
For transponder use (1080MHz) the table lists up to 18 dB/100ft for
RG400 and up to 38(!)dB/100ft for RG-316. That is substantial,
Rob
RG-400 6.4 kg/100m
RG-316 1.6 kg/100m
...chris
rv8iator
PostPosted: Wed Dec 13, 2023 1:35 pm    Post subject: RG-316 v RG-400 Reply with quote
Rob...
All good points and I appreciate your confirmation and critique.
Xponder and GPS RG-400, Comm & Nav radios RG-316.
I am on a weight diet... trying to keep unnecessary weight gain from getting away from target weight.
I have all the dies for crimping RG-316 as it is nominally the same dimensions as RG-174.
...chris
On Wed, Dec 13, 2023 at 12:18 PM Rob Turk <matronics(at)rtist.nl (matronics(at)rtist.nl)> wrote:
--> AeroElectric-List message posted by: Rob Turk <matronics(at)rtist.nl (matronics(at)rtist.nl)>
wrong sheets.
Rob
> RG-400 6.4 kg/100m
> RG-316 1.6 kg/100m
> ...chris
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
C. Stone (RV8iator)
