wamflight(at)gmail.com Guest
Posted: Mon May 06, 2024 4:33 pm Post subject: Yak50 |
I need rubber seals for landing gear actuators. Anybody know where to get them? Are they the same as the 52?
Bill
JB Soar
Posted: Mon May 06, 2024 4:40 pm Post subject: Yak50 |
John Warwick has many parts for the Yak aircraft..."The Yak Collection."
On Mon, May 6, 2024 at 7:37 PM Bill <wamflight(at)gmail.com (wamflight(at)gmail.com)> wrote:
[quote]--> Yak-List message posted by: Bill <wamflight(at)gmail.com (wamflight(at)gmail.com)>
Bill
fishmouth500
Joined: 07 Apr 2015 Posts: 43 Location: Southern California
Posted: Mon May 06, 2024 5:15 pm Post subject: Yak50 |
Thanks JB!
Actually I’m now seller “Fishmouth500” on eBay …65 products and counting…but unfortunately… no Yak 50 main gear seals🙁
619 933-2571
On Mon, May 6, 2024 at 5:44 PM John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
| Quote: | John Warwick has many parts for the Yak aircraft..."The Yak Collection."
| Quote: | --> Yak-List message posted by: Bill <wamflight(at)gmail.com (wamflight(at)gmail.com)>
Bill
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
markbitterlich(at)embarqm Guest
Posted: Mon May 06, 2024 10:18 pm Post subject: Yak50 |
They are not the same as the 52. They are "chevron" seals. Two types actually. The large one is the same as the actuator inner diameter, these are the ones that are leaking. There is also a smaller seal. Can't remember the size. It was 25 years ago.
Be aware that the left and right actuator end pieces are different. Don't mix them up. Also be aware that the end pieces do screw off, but there is a small lock screw in the end pieces that is often covered by paint. Without loosening those small lock screws, the end caps will NOT come off. Ask me how I found THAT out! Take pictures before taking apart.
Getting those actuators out (and back in) is no easy task. For ME it was easier in the end to remove the whole gear leg attached to the actuator after jacking.
Also when removing the actuator hoses, be aware of the flow restrictors that are in the fittings that will fall out never to be seen again. They are 37 degree pieces that go INSIDE of the fitting you unscrew. Don't lose these things, they are IMPORTANT!!
I think Jill at M14.com rebuilds these things or at least used to.
Good luck,
Mark
Date: 5/6/24 9:19 PM (GMT-05:00)
To: yak-list(at)matronics.com
Subject: Re: Yak-List: Yak50
Thanks JB
619 933-2571
Bill
FORUMS -
WIKI -
b Site -
JB Soar
Posted: Tue May 07, 2024 2:14 pm Post subject: Yak50 |
John-
Good evening from EGLL. I'm at the hotel in Kensington. There is a "Warwick Street" nearby, so you must be famous?
While I'm waiting for hoses, I'm considering some other changes to the Yak 55: Has anyone installed "winged" Dzus fasteners on these aircraft?
Having them allows one to open the cowl doors without a screwdriver. Maybe this isn't important?
I've got the Scott 3200 tailwheel on the 55... Yea, it works fine. I'm thinking about going back to the original tailwheel. The Scott doesn't
really offer an improvement, other than allowing one to push the airplane backwards. In the hangar, I'm better off pulling the airplane backwards,
and uphill, with the T-handle that the previous owners made... It works with the original tailwheel. 'Turns out, so many improvements were not
improvements. Stupid! Optimistic! My expectations were clouded and unreasonable!
Hose news? We need hoses for the 55 and the 50. 'Might as well get the stuff done...
The breakfast can't buffet can't open soon enough... 7 more hours, more or less...
jb
On Mon, May 6, 2024 at 8:20 PM John Warwick <john.warwick1(at)gmail.com (john.warwick1(at)gmail.com)> wrote:
| Quote: | Thanks JB!
619 933-2571
JB Soar
Posted: Tue May 07, 2024 2:32 pm Post subject: Yak50 |
John-I have one spare Scott 3200 tailwheel adapter on the shelf. 'Fact, I'd go back to the original tailwheel and
sell the Scott... It's expensive now! 3-4 grand? 'Might be the 3400?
Maybe peddle this stuff on your website, along with the Payne Aviation electronic ignition?
These airplanes are best left alone, and flown.
jb
| Quote: | Thanks JB!
619 933-2571
