wamflight(at)gmail.com Guest
Posted: Tue Apr 30, 2024 2:25 pm Post subject: Ouch |
Can it be fixed?
Description: |
Filesize: |
1.83 MB |
Viewed: |
306 Time(s) |
richard(at)rgaeros.com Guest
Posted: Tue Apr 30, 2024 11:48 pm Post subject: Ouch |
That looks like a V-530 propeller on a Yak 50, and I would suggest it cannot be repaired. But, interestingly, if it were an MT propeller that had significant damage even to the last foot of the blade, new wood can be inserted. A very crude "repair", given that the damage only extends, as it seems from the photograph, a few inches into the blade is to cut that end of the blade and do the same on the other side, matching the distances as precisely as can be done. At least you would then have a working propeller, but obviously put a good sealing compound into the exposed wood. But of course, probably best to get a new pair of blades from Whirlwind!
PLEASE NOTE NEW EMAIL ADDRESS.
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120
e-mail: richard(at)rgaeros.com (richard(at)rgaeros.com)
www.rgaeros.com
WORLD LEADERS IN EAST EUROPEAN & CHINESE RADIAL AIRCRAFT ENGINES
In partnership with Aerometal Kft, Hungary.
Description: |
Filesize: |
5.62 KB |
Viewed: |
295 Time(s) |
Description: |
Filesize: |
5.26 KB |
Viewed: |
295 Time(s) |
Posted: Wed May 01, 2024 4:14 am Post subject: Ouch |
Thanks Richard. Ran out of air during taxi.
Airport Taxi light jumped in front of me!
[quote]On May 1, 2024, at 02:52, Richard Goode <richard(at)rgaeros.com> wrote:
 v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> Clean false false false false EN-GB X-NONE X-NONE {C4468088-A8C9-4B35-BED7-53E862669C63} 1712682344752 <![endif]--> <![endif]-->(at)font-face { font-family: "Cambria Math"; } (at)font-face { font-family: Calibri; } p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm; font-size: 11pt; font-family: Calibri, sans-serif; } a:link, span.MsoHyperlink { color: rgb(5, 99, 193); text-decoration: underline; } a:visited, span.MsoHyperlinkFollowed { color: rgb(149, 79, 114); text-decoration: underline; } p.MsoPlainText, li.MsoPlainText, div.MsoPlainText { margin: 0cm; font-size: 14pt; font-family: Calibri, sans-serif; } span.PlainTextChar { font-family: Calibri, sans-serif; } .MsoChpDefault { } (at)page WordSection1 { size: 612pt 792pt; margin: 72pt; } div.WordSection1 { page: WordSection1; }/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-hansi-font-family:Calibri; mso-bidi-font-family:"Times New Roman"; mso-font-kerning:1.0pt; mso-ligatures:standardcontextual; mso-fareast-language:EN-US;} <![endif]--> <![endif]--> <![endif]-->
<image001.png>
www.rgaeros.com
<image002.png>
Posted: Wed May 01, 2024 5:00 am Post subject: Ouch |
Oh dear – these things do happen unfortunately. But yes, the emergency a bottle will work the brakes.
Richard
www.rgaeros.com
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> On Behalf Of Bill
Sent: 01 May 2024 13:14
To: yak-list(at)matronics.com
Subject: Re: Ouch
<![if !supportLineBreakNewLine]><![endif]>[quote]
On May 1, 2024, at 02:52, Richard Goode <richard(at)rgaeros.com (richard(at)rgaeros.com)> wrote:
<image001.png>
www.rgaeros.com
<image002.png>
Description: |
Filesize: |
5.62 KB |
Viewed: |
293 Time(s) |
Description: |
Filesize: |
5.26 KB |
Viewed: |
293 Time(s) |
Posted: Wed May 01, 2024 11:05 am Post subject: Ouch |
Sitting in the hanger, gear down, turn on main air valve, big leak and gear handle. Gear to neutral = No leak???
[quote]On May 1, 2024, at 08:05, Richard Goode <richard(at)rgaeros.com> wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> Clean DocumentEmail false false false false EN-GB X-NONE X-NONE {1D9F8BF5-6E00-4A98-8B7F-BA860B75214B} 2446933683552 <![endif]--> <![endif]-->(at)font-face { font-family: "Cambria Math"; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: Consolas; } p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm; font-size: 11pt; font-family: Calibri, sans-serif; } a:link, span.MsoHyperlink { color: rgb(5, 99, 193); text-decoration: underline; } a:visited, span.MsoHyperlinkFollowed { color: rgb(149, 79, 114); text-decoration: underline; } p.MsoPlainText, li.MsoPlainText, div.MsoPlainText { margin: 0cm; font-size: 14pt; font-family: Calibri, sans-serif; } p.msonormal0, li.msonormal0, div.msonormal0 { margin-right: 0cm; margin-left: 0cm; font-size: 11pt; font-family: Calibri, sans-serif; } span.PlainTextChar { font-family: Consolas; } span.plaintextchar0 { font-family: Calibri, sans-serif; } span.EmailStyle22 { font-family: Calibri, sans-serif; color: windowtext; font-weight: normal; font-style: normal; } .MsoChpDefault { font-size: 10pt; } (at)page WordSection1 { size: 612pt 792pt; margin: 72pt; } div.WordSection1 { page: WordSection1; }/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman",serif;} <![endif]--> <![endif]--> <![endif]-->
Richard
<image001.png>
www.rgaeros.com
<image002.png>
Subject: Re: Ouch
<image001.png>
www.rgaeros.com
<image002.png>
markbitterlich(at)embarqm Guest
Posted: Wed May 01, 2024 12:41 pm Post subject: Ouch |
Bill, that usually means that one of your gear actuators has an internal leak. The air goes through an internal actuator seal to "the other side" and then vents through gear handle. Putting gear handle in middle removes air from going to actuators. Yak-50 anyway. Talk to Dennis Savarese regarding 52's.
Mark
Date: 5/1/24 3:09 PM (GMT-05:00)
Subject: Re: Yak-List: Ouch
(at)font-face { font-family: "Cambria Math"; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: Consolas; } p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm; font-size: 11pt; font-family: Calibri, sans-serif; } a:link, span.MsoHyperlink { color: rgb(5, 99, 193); text-decoration: underline; } a:visited, span.MsoHyperlinkFollowed { color: rgb(149, 79, 114); text-decoration: underline; } p.MsoPlainText, li.MsoPlainText, div.MsoPlainText { margin: 0cm; font-size: 14pt; font-family: Calibri, sans-serif; } p.msonormal0, li.msonormal0, div.msonormal0 { margin-right: 0cm; margin-left: 0cm; font-size: 11pt; font-family: Calibri, sans-serif; } span.PlainTextChar { font-family: Consolas; } span.plaintextchar0 { font-family: Calibri, sans-serif; } span.EmailStyle22 { font-family: Calibri, sans-serif; color: windowtext; font-weight: normal; font-style: normal; } MsoChpDefault { font-size: 10pt; } (at)page WordSection1 { size: 612pt 792pt; margin: 72pt; } div.WordSection1 { page: WordSection1; }
Richard
<image001.png>
www.rgaeros.com
<image002.png>
On May 1, 2024, at 02:52, Richard Goode <richard(at)rgaeroscom (richard(at)rgaeros.com)> wrote:
<image001.png>
www.rgaeros.com
<image002.png>
