Rowland_Carson
Joined: 04 Jul 2008 Posts: 155 Location: Cheltenham, England
Posted: Mon Oct 28, 2024 4:17 am Post subject: cowl to spinner clearance [was: Re: Re: Europa-List Digest: |
On 28 Oct 2024, at 08:52, James Kelly <europajimkelly(at)gmail.com> wrote:
| Quote: | Hello Airmaster owners. I have a new Airmaster prop fitted by an aviation expert I understand that the clearance between the cowlings and spinner should be 6mm minimum to 12mm maximum. I have only 3.5mm how can I make the adjustment ???
{big snip of all other posts in the digest}
James - in my conversations with Neville Eyre, he said that the clearance between spinner and cowl should be the thickness of 2 or 3 mixing sticks (about 3mm to 5mm). I have also heard from Andy Draper that the ideal clearance is 3mm.
I sounds as though your setup is fine already - I wonder why Airmaster would suggest a larger clearance than that recommended by the factory experts.
in friendship
Rowland
| Rowland Carson ... that's Rowland with a 'w' ...
| <rowlandcarson(at)gmail.com> http://www.rowlandcarson.org.uk
| Skype, Twitter: rowland_carson Facebook: Rowland Carson
