| Rowland_Carson
				|  Posted: Mon Oct 28, 2024 4:17 am    Post subject: cowl to spinner clearance [was: Re: Re: Europa-List  Digest: |   |
				| On 28 Oct 2024, at 08:52, James Kelly <europajimkelly(at)gmail.com> wrote:
  	  | Quote: |  	  | Hello Airmaster owners.  I have a new Airmaster prop fitted by an aviation expert I understand that the clearance between the cowlings and spinner should be 6mm minimum to 12mm maximum.  I have only 3.5mm how can I make the adjustment ???
 {big snip of all other posts in the digest}
 James - in my conversations with Neville Eyre, he said that the clearance between spinner and cowl should be the thickness of 2 or 3 mixing sticks (about 3mm to 5mm). I have also heard from Andy Draper that the ideal clearance is 3mm.
 I sounds as though your setup is fine already - I wonder why Airmaster would suggest a larger clearance than that recommended by the factory experts.
 in friendship
 Rowland
 | Rowland Carson          ... that's Rowland with a 'w' ...
 | <rowlandcarson(at)gmail.com>            http://www.rowlandcarson.org.uk
 | Skype, Twitter: rowland_carson      Facebook: Rowland Carson
